DucktileMedia
Please show some flying shots from the HFP. Im all for discovering the new MK. I find it hard to give in to them for some reason. Im all a mac guy too. I had to salvage my wifes old pc just for my helicopter. Ick.
Didnt the camera mount on crack routine turn out to be something other than the HFP?
Ken,
I can easily say that video is smoother than I expected.
Now I'm sitting here considering turning the Droidworx AD-6 into a Y6, really wouldn't take much to make the change...
So... you like the config Ken?
Allright! Are you going to stick with the same motor mounts or use Rusty's large mounts? You should definitely try the regular ones first, I think they will be fine. I have the large X-mounts of his for my Y-6. You have to use them with the metal x-mount that comes with the motors unless you are will to trust two screws to hold the motor or drill your own two additional holes. I think we should talk Rusty into adding the two holes to these mounts for Avroto/Pulso type motors. I am also using two standoff's on the end of the mounts for more support.
Excited to see how it comes out for you!
Shawn
I'm going to give it a go with the same motor mounts for now. One thing I am going to do is make a set of aluminum standoffs to go between the upper and lower mounts to keep them square to each other and add a bit of strength for the bigger and heavier motors. I've got plenty of 6061 round stock and it won't take but a half hour or so to cut 6 small pieces and drill/tap them on each end for screws. I think just the two 4-40 screws holding the mounts on now is marginal for big motors and props, tying everything together and maybe going to a 4mm bolt though the mounting blocks will give me more confidence that it's all going to stay together carrying a load.
Might also try milling a larger engine mount to see how much work it is to make one without CNC equipment. I have a choice of Delrin or aluminum though I think I'd go with aluminum for some added heatsink for the lower motors. I did notice out at the field yesterday in the heat the lower motors were getting HOT, enough that I couldn't hold my finger on them immediately after landing. By the time I got back to the car and checked with the temp gauge I was getting readings around 125 so they had to be at least 10 degrees hotter on landing. I'm hoping the Avrotos will run a bit cooler since they won't be working as hard to keep it flying.
