Just about to start the build of a Y6, a first for me. I've flown a lot of different configurations but never a Y6, so when it became obvious that the Hoverfly board wasn't happy in its MK quad frame home I decided to take the opportunity to not only give it new frame but also to try out a setup I've never flown before.
A lot of people say the Y6 is the best all around frame setup for APV, and since that is the alleged main purpose for the existance of the Hoverfly Pro flight controller it seemed like a good idea to put the two togther and see what comes out at the end of it all.
Now keep in mind this is not an entirely new build as most people think of it, a very large percentage of the bits to be used have already seen flight time in various projects I've tinkered with as well as having been part of the old Hoverfly quad. Nice thing about the frame set I got is that if I decided I want to try an X8 again it will do it, all I need to do is move the existing 3 arms and add the fourth, so I have options if I decide the Y6 isn't it.
Here's all the bits that will be going into the build...
The frame I'll be using is Rusty's Rev 8. http://www.shop.aglhobbiesllc.com/Rusty-s-Rev-8-Frame-Kit/Rev-8-Frame-Kit.html
I already have one of his mini quad frames flying as home to my Quadrino board and its proved very sturdy so far, the only change I made when ordering the Rev 8 was to spec it to be used with 1/2 square arms for a couple of reasons. First I have a large supply of 2 foot long pieces of 1/2 inch square alloy already on hand, and second for use as an APV craft I want the arms to be solidly located with no chance of the motors rotating on the arms as they can do with round stock. Here's the frame bits...
The flight controller as mentioned will be my well used Hoverfly Pro board, one of the first off the production line in the fall of last year, and also a source of never ending aggravation at times. Here's its chance to redeem itself, I know some of the problems I was having with it were due to the MK quad frame not being an ideal match for the H/F, if it can't fly well AND work a camera mount in the new frame then I'll admit defeat and retire it in favor of something else...
Motive power will be provided by a set of well broken in Flycam 925 motors powered through a set of also well proven Turnigy Plush 18 amp ESCs and turning a set of Graupner 10 x 5 props top and bottom for the time being. The props may change at a later date, for now I'll go with what I have a lot of, so the Graupners are it.
Other odds and ends being recycled are my original MK Hisight II camera mount, also likely to be replaced with something better should the Y6 prove itself worthy, for now it gets the Hisight because I have it and know what to expect from it. Likewise the same Turnigy 3S 2650 packs that previously powered the H/F quad will once again see duty on the Y6.
The last new bits for the time being are some LEDs I've had sitting around for a while. Since the Y6 configuration will be a new flying experience for me, the plan is to add a full length strip of lights on the underside of the rear boom and some as yet undetermined number of a different color on the outer sides of the front booms to aid with visual orientation at a distance...
So I think I have everything I need to make this happen and it shouldn't take too long as the only soldering that needs to be done is to build a new power harness, the rest of it has already been flown and just needs to be bolted together in the new frame.
Time to start building!
