helloman1976
Ziptie Relocation Expert
I don't mean to resurrect and old thread; but, I've been having some issues with throttling revving when switching to manual mode even during bench testing without props (WKM FW 5.26). I understand that I can set up an individual throttle curve for each flight mode. But, there's something strange going on that I don't understand. If I do CSC in manual mode and then switch to either atti or gps, there's no significant change in motor rpm, regardless of how many times or in what order I switch between the different flight modes. However, if I do CSC in either atti or gps mode, and then switch over to manual mode, there is a significant revving of the motors, and it happens every time I switch over the manual mode. If I switch back to gps or atti, the motors go back to normal rpm. Any ideas about what's going on here?
I don't know the WKM module well at all but unless you can setup a throttle curve inside of its programming I wouldn't mess with that. Setting up a throttle curve on your copter is a big NO NO. Can it be done? Sure, but with consequences. You'll never have centered sticks for example and there a myriad of problems that come with that alone.
The proper way to setup your copter when using it with a NAZA (WKM might be different) to avoid that revving is to make sure you can hover at 50% throttle in manual mode. I personally change my props to make this happen. If I hover at 50% in manual mode and I switch to GPS/ATT mode then there will be no change in power because 50% in GPS mode IS hover and so if they match, no power change. If I hover at 40% in manual mode and switch to GPS/ATT mode it'll drop like a rock and you'll have to "catch it" from falling, this is completely normal. Manual mode disables ALL compensation, that's the point of it. You could also call manual mode "sport mode" and that would be appropriate as well. Your settings will depend entirely on your setup and no-one will be able to tell you which settings are too low or too high for your setup, they'll only be able to get you close. You'll have to fly it to see if it's to your liking and if it's flying stable like you want. There are no standards when it comes to settings, only preferences.
