MadMonkey
Bane of G10
I'm finally to the point of asking for input
I built a Tarot FY650 a while back and have been chasing a yaw problem ever since.
Motors are Sunnysky X4108S 600KV with APC 12X3.8MR props. ESCs are ZTW Mantis 20A. I'm using 4S 4000/5400 batteries. Controller is a Naza V2.
I've tried every combination of gain settings I can think of to fix this and nothing works.
Pitch and roll are perfectly stable and spot on, no problems at all. At high gains it's very snappy and responsive with no stability problems whatsoever.
Yaw is another story.
When yawning quickly to the left or right (seems worse to the right), the aircraft will tilt sharply, diagonally. If I yaw right, the right front motor will rise briefly abd the aircraft will go unstable for a moment. It'll usually recover fine, but a couple of weeks ago I was doing a sliding pan across the field and it went almost completely out of control but I was able to stabilize before it hit the ground (using atti/GPS only).
Things I've done to fix it...
Balance was first. The gimbal and batteries are both on the same rails and can be slid back and forth for longitudinal balance and the battery can be moved sideways for lateral. I've tried centered, far forward and far aft CGs with little difference.
The measurements for the GPS antenna were double checked and correct.
All motors were re-aligned to make sure they're completely vertical.
I pulled the controller off and put it on my old testbed F450 and it worked flawlessly with Afro ESCs and crappy Turnigy motors, no yaw problems whatsoever.
(ETA: Also recalibrated all the ESCs to no effect).
Since this is the case, I believe this narrows it down to a motor or ESC issue. If anyone has any other ideas before I pull out the Mantis ESCs and replace them with 30A Afros, I'd like to hear them.
I considered a prop change because of the possibility of slow motor response, but with pitch and roll having no problems that doesn't sound like a likely answer.
Thoughts?
Thoughts?
