Tarot 690 Hex and all related parts and support equipment. The whole thing can be transported in its wheeled, custom foam fitted case (fully assembled, w/o props). In the field doubles as a launch surface.
Following is the specs and manifest of included parts, equipment. It would make a fantastic platform not having to configure and debug an entire system, without costing 5-10k for a large format Hexacopter that currently you find offered.
Here is whats included:
Tarot FY690S Frame
Tarot 680 Pro Motor Mounts
Tarot 680 Pro Landing Gear Locks
IPower Multimate MT2814 750 kv motors
Hobbywing Platinum Pro 30A OPTO ESC's
DJI NAZA-M Lite Flight Controller w/ GPS
DJI PMU V2 w/ LED
1345 CarbHQ Prop 12x6 Props (2 sets of 6)
Self tightening Quick Disconnects w/ adapters
2 - Turnigy Nano-Tech 35C 5000 mAh 4S Batteries
Foam Skids
Tarot Folding GPS Mount
Custom Aluminum standoffs w/ 2nd battery tray to top mount flight battery
Hex Power Distribution Board
HobbyWing Platinum Pro Programming Box
Turnigy 9X Transmitter w/ 2650 mAh Lipo
Turnigy 9X Receivers (2)
Venom Pro 2 Charger
Custom Rolling case (foam fitted) for transport (Hex remains assembled w/ GPS, Gimbal and Camera)
The package includes a multitude of spare parts, extra DJI Naza-M lite flight controller (I was going to hack into a Naza V2), other spares include:
Turnigy 9X Transmitter (for parts)
Turnigy Multistar 30A OPTO ESC's (6)
ZTW Spyder 30A OPTO ESC's w/ Simon K (6)
Tarot 2nd Battery Tray (to run dual batteries)
Tarot 690S motor mounts (6)
Assorted 10mm Carbon fiber tubes
1155 Carbon Fiber Props (6)
Tarot Misc. accessories (battery pad, tube clamps (2))
Misc Hardware (2.5mm, 3mm screws, standoffs, etc)
Misc. cables (for FC)
Price for the Hex complete is $850 (+ any Paypal, Shipping fees), that includes the custom foam fitted case for transport, it can also be picked up in person (cash in hand, or prepaid) Monterey, Ca 93940 if you would like.
Also offered, I will throw in for an extra $275:
Frsky 16 Channel 8XR (16 Ch.) (frequency hopping) 2.4gHz Receiver
Frsky Taranis X9D Plus (frequency hopping) 2.4gHz Transmitter
Frsky Lipo Telemetry Sensor
Frsky Altitude Telemetry Sensor
3D Printed mount for X8R antennas
Fitted Aluminum case for Radio
Outside of that, that is offered separate or combined at an additional $350 is:
Zippy Compact 40C 6200 mAh 4S batteries (2)
Zippy Compact 30C 8000 mAh 4S batteries (2)
Lipo safe bags (3)
Hobby King 350W 13.8V power supply
Turnigy Reaktor 300W 20A balance charger
Hobby King parallel charging board
Turnigy 130A power analyzer
Gimbal and related components are offered as a module of this setup for an additional $300
ACK Pro Carbon 2 Axis Gimbal
Complete w/ Controller and vibration isolators
and mounting hardware (std. 10mm CF tube)
900 mAh Battery (1), for gimbal
RF to IR shutter release cable
If you want the whole aerial photography/video package, the Camera will be offered at a seperate cost outside of the above mentioned equipment for $450, which includes:
Sony NEX 5N Camera w/ 3 batteries
Sony 16F28 16mm F2.8 lens w/ hood, caps
Sony VCL-ECU1 Ultra Wide Angle Adapter (.75) w/ case, caps
Sony 5N battery charger
49mm UV Filter
Camera flsh and Camera bag are included
I will not be parting this out , I will however discount the entire package (w/ all components above) if bought together. lowball offers will be ignored and am not looking for trades right now. Thanks.
With it all together, here are the specs for the complete build:
3.7 kg AUW w/ camera (16mm lens, gimbal & 6200 battery) (3.9 kg w/ 8000 battery)
Telemetry logging enabled for Lipo cells / altitude, switched @ radio
Gimbal tilt control from radio
Camera Shutter / Movie mode from radio
Naza IOC works (home lock, course lock), switched @ radio
GPS, ATTI, Manual mode, switched @ radio
Failsafe programmed for both Taranis and Naza
Feel free to contact me by PM if your interested. Thanks again.
Tarot FY690S Frame
DJI PMU V2 w/ LED
Foam Skids
Venom Pro 2 Charger
Lipo safe bags (3)
49mm UV Filter
