T-motor CF props vs clones - a comparison
Hi guys,
I broke a prop (and an arm) last month, and have been waiting what feels like an eternity for someone to get 1450 t-motor CF props back in.
Last week though, some clones came to my attention. I immediately ordered them, and below are my thoughts and observations when comparing the two brands side by side. I order 1455 and 1355 clones. I got the 13"'s because the ecalc calculation results are "safer" - the 14"'s at full throttle at 6S exceed the theoretical maximum of my motors by 10%, even though I sacrifice flight and hover time in the process. Give the power of the motors and 6S though, my chances of requiring full power are almost nil.
It should be noted that the clones were $50 *a set*...original T-motors are $50 *each*. Are the clones worth it? Lets find out....
Pic 1: as we can see the clones is an extremely close match to the original. The clone is 1455, but the T-motor is 1450, but for the life of me, I cannot tell the difference. Hopefully "Hardy" won't notice either. The angle of the shot makes the clone look shorter. Its not - it's definitely 14".
Pic 2: The clone is glossed, whereas the original is matt. You can tell the gloss adds weight, but I don't have a sensitive enough scale to prove. But in the hand, the original is lighter. The quality of CF in the original is also better, or at least the gloss has added some surface imperfections that aren't in the original. Notable is that the original's carbon weave is exactly 90' to the line of the prop. The clone is slightly squint. Personally, I like to think the original has more attention to detail and quality because of this. This could be critical in flight, where you want absolute integrity. Is squint weave a sign of weakness? Time will tell I guess. There are some horror stories in the cycling world due to clone carbon frames snapping and cracking too easily. That plays at the back of my mind, at least.
Pic 3: Do they fit? Yes they do. Very neatly in fact and you don't need the t-motor spacer ring either. However, check out that air gap on the blade bridge. That's a sign of things to come...
Pic 4: Ok, now we can really tell these are cheap clones. Compare the mounts of the original and the clone. The original has very smooth and even holes, and the edges are chamfered to aid screw and pole guidance. Good attention to detail. The clones...well. The drill was obviously blunt because the carbon thread is leaking out (those are not cracks btw). The finish is terrible. There are scratches on the finish. And you can see there's an imperfection in the bridge (it looks like a shadow). That could be a potential prop disintegration point. The 13"'s are similarly poorly finished.
View attachment 11834View attachment 11835
Finally, the most telling part. The balancing. Of the 8 t-motor props I have (4x14" & 4x11") only 2 needed a very light rub, and bingo. No hubs needed balancing at all. It took 1.5 hours to do all 4 clone blades on the du-bro. They all needed significant blade balancing and only one needed no hub balancing. I suspect the results could have been better for the blades if the gloss finish was not used. There is no excuse for the amount of filing and super-glue weighting I had to do on the hub though...that's where the poorer clone moulds show their weakness.
At the end of the day though, will I fly the clones? Yes. But they will need to earn my confidence, whereas the t-motor originals felt great from the start, and I had confidence in them the moment I fired up the motors. Will report back in 20 flights...if they last that long...(still grounded though...I broke an arm in the same crash, and that's still stuck in Swiss customs!).
Edit: The clones are here btw: http://www.foxtechfpv.com/1455-mkii-carbon-fiber-propeller-cwccw-p-1025.html
Excellent info here...
BTW - I have worked quite a bit with carbon fiber making and finishing my own large 4" diameter tube for a different hobby ofcourse and have also manufactured carbon fiber 1/8 plate using a vacuum bagging system. The optimum ratio of carbon fiber to the epoxy binder is 60% cf to 40% epoxy...... typically I can get to 55% CF and 45% epoxy. The quality of epoxy can vary alot. The best will be the type that allows for post curing in an aclave oven (adds considerable strength and greater heat resistance). Unfortunately epoxy will break down over time due to solar UV radiation and will also absorb moisture. So keep the props dry when sanding them or you may find it more difficult to achieve the needed balance.
A sure sign that there is not enough epoxy in the final result or the epoxy did not migrate in between all the strands is that there will be little CF crumbs and tears where holes are drilled. However even an imperfect CF prop can be very strong. CF props are not only very light but some are also extremely thin..... the end result is there tends to be a lot less vibration intensity due to the reduced angular mometum.
The glossy finish is a clear gel coat but the epoxy type not the more common polyester resin dye type used for showers, bathtubs, boats etc.
The fast and perfect way to add the gel coat is via a mold. It provides some additional moisture and UV protection.
Hi guys,
View attachment 15072View attachment 15073
Thalios
There are many many different quality in "clone" blades.
I found that RCtimer CF props are extremely soft and need a lot of balancing.
Maytech props are nice, fairly rigid and require little balancing
DYS props are the best of the clones. Very rigid, very nice finish, require very little balancing. Comparable to RC-tiger props.
Thalios
I've been running their 15x5.5 props on 580Kv pancake motors and they work awesome. Paddle style is not a requirement.
cbpagent72
Awesome review, thanks for taking the time to do a review like that. I was looking at the clones but not anymore. I would love to hear a Xoar vs Tmotor prop review.
Sent from my SPH-L720 using Tapatalk
ovdt
Great review. Can you tell me about the noise that the props creates? People claim that T-Motor props are very silent. Is that true?
Foxtech also sells the Supreme series carbon props. They claim that they are the same with T-Motors. The prices are at the same level.
