GotHeliRC.com Swiftcam G3S 3 axis auto stabilizing gimbal for 4 GoPro Hero 3, 3+ Hero 4 Camera
GotHeliRC
http://gothelirc.com
http://www.gothelirc.com/products/3...ng-gimbal-for-4-gopro-hero-3-3-hero-4-camera/
Swiftcam G3S 3-axis stabilizing technology for GoPro
Aerial filming stabilizing technology in your hand!Built with stabilizing technology for aerial filming, SwiftCam G3s helps the energetic you take perfectly smooth videos in vibrant activities in a simple and easy way.
Versatile shooting modes
Switch between three shooting modes designed to unleash your imagination in all occasions. Choose to allow GoPro to follow your action or lock it to designated axis simply by pressing the smart joystick on SwiftCam G3s.
360-degree horizontal pan
Capture all the vivid lives in the surrounding world with SwiftCam�s unique 360-degree horizontal pan.
Contemporary design
SwiftCam G3s is designed with your style and comfort in mind. From the sleek power indicator to the ergonomic handgrip, as well as the fully plug & play system design, SwiftCam makes sure you are always a class above.
Magnetic Locking
The clipping arm structure is designed to hold magnetically in its desirable position when not in use to ensure convenience in storage and travel.
Mount All GoPro
Fit all latest GoPro models including Hero 3 to 3+ and 4. Designed to give full vision of LED screen of GoPro Hero 4 after mounting on the device.
Extension Pole
Extend your imagination with the optional extension pole that will come soon. Alternatively, the standard tripod adapter allows you to use your own equipment for greater flexibility and savings.
Specifications
HandHeld Gimbal
Model: SW-HG-G3s
Operating Angles:
Pan axis: 360 degrees
Pitch axis: 0 - 270 degrees
Roll axis: +/- 50 degrees
Supported Devices:
GoPro Hero 3, GoPro Hero 3+, GoPro Hero 4
Modes:
Mode/Axis Pan Axis Tilt Axis Roll Axis
Full Follow Mode Follow Follow Lock
Follow Pan Mode Follow Lock Lock
Lock Mode Lock Lock Lock
Weight: (Battery Included): 374g
Dimensions: 309.05H x 80.11W x 46.97D (mm)
Expanded Dimensions: 276.28H x 96.23W x 80.8D (mm)
Battery Requirements:
Battery Type: AAA alkaline battery 1.5V x 4 - LR03 / UM4 or AAA rechargable battery 1.2V x 4 - HR03 / UM4 (batteries not included)
Operating Temperature Range -10 to 40 degree Celsius
Package includes:
G3s x1
Flannel bag x 1
U Mount x 1
USB data Link Cable
