I check there is upgrade to 1.0.8.3 i have the 8.2 so i upgrade to that i think firmware is same.
The sequence is as stated in the manual, There is NO compromise! first rotate the vehicle level and 360 degrees need to do this 2 or 3 times until the green led pulses slowly, prior to this it flashed fast as you rotated, then move to have the vehicle front point vertical upwards, and rotate again 360 degrees 2 to 3 times until LED slow pulses green, then turn vehicle on it's side and rotate as before until led turns solid green, if it turns red you did it wrong, do it again.
I purchase the SuperX Flight Controller Standard and I can not get it to work in a Tarot T960 C/F Folding Hexacopter
Thanks.
Yes it would did you buy from Hobby Wing if you did ask amy for help thru skpye i bought mine there or rcgroup may know some thing. http://www.rcgroups.com/forums/showthread.php?t=1963789
Only 4 props will spin when you have basic version plugged into a Hex or Y6 build. I just installed and waiting on my Basic to Standard upgrade, and noticed this when I tried to arm the y6 I just installed it on. Ordered it 4 days ago from Xaicraft America and still don't have the code yet. Xaircraft website does not seem to be functioning either. I can't get the link from the GUI to reach an update page (no it is not the same firefox issue).
I purchase the SuperX Flight Controller Standard and I can not get it to work right at all. all the lights are good it takes about 3 to 5 mins to lock but I can’t get it off the Ground. It tips to the random side. I have it in a Tarot T960 C/F Folding Hexacopter with Hobbywing 40A OPTO flyfun ESC and foxtech 5008 340kv motors, I had no problems setup the SuperX or the ESC and I also replaced the ESC, yes I purchase two sets of ESC I will use a set on my next multirotor, Can someone please help.
Thanks.
Have you calibrated the throttle endpoints in the ESCs with your Radio? This is separate from the SuperX controls calibration. The ESCs need to be told what your radio considers full throttle and what it considers low throttle.
I've seen this same exact wobbly behavior with a different flight controller that I forgot to set the throttle end points in the ESCs.
Might give that a try, hope it helps.
