Hi Dave
What Planet? Ha! I am in Los Angeles. Not lift wise but performance wise
Jon
Is that LA speak!?
R u flying mrs at the moment?
Hi Dave
Jon
I dont think Aeronavics are doing any for a while as they whee overrun with orders. Where about's are you on the planet?
I wonder why people keep on saying that a coaxial propeller is less efficient?
Since as long as the coaxial propellers are contra rotating they are more efficient than single props:
http://en.wikipedia.org/wiki/Contra-rotating_propellers
Contra rotating propellers and fans have been applied in aircrafts, wind tunnels, submarines, outboard motors, gas turbines, wind turbines etc.
The only reason why this concept is not always applied is because contra rotating propellers are more complicated than single props and can be noisier.
But those issues wouldn't apply to a X4 as opposed to an Octocopter.
... But let's assume that the statement is correct....
anything up to 94% less efficient than a flat 8
But let's assume that the statement is correct. The statement is that TWO propellers in a contra-rotating setup is 6% - 16% more efficient than a SINGLE propeller. So that means that in an X8/X4 configuration, 8 props in Contra-Rotating configuration can be up to 16% more efficient than FOUR SINGLE props. In a Flat 8 Octocopter, you have 8 props that are separate so the total arrangement is still more efficient than if they were in a coaxial set up. So based on that statement, for a contra-rotating setup to be more efficient than a flat 8, you would need 16 propellers.
Well, not really, although I should have written 74%. It was just to make the point that the way it was worded suggested a co-ax arrangement is really inefficient.
If a flat 4 has 50% of the power of a flat 8 and a coax 8 is 6% more efficient than a flat 4: 4 x 6% = 24; 50 + 24 = 74%.
Of course this is an entirely non-scientific argument because if you take the 16% value and apply the same formula the co-ax ends up being more efficient than the flat 8: 4 x 16% =64; 50 + 64 = 114% !!
As you say, as long as it does the job, who cares what the loss in efficiency of the more manageable co-ax airframe is, but it would be interesting to know what the power loss is.
... It would be nice to see some real-world numbers, if for nothing more than to satisfy curiosity... :tennis:
A flat 8 octocopter is not more efficient than a flat 4 quadrocopter, it can just carry double the load (but it also consumes double the power - so the efficiency remains unchanged).
Then the following statement is contradictory:Two coax rotating propellers ARE more efficient than a single propeller.
But it is still less efficient than two separate propellers.
You misunderstood.Saying that if a contra rotating propeller is more efficient than a single propeller than they must double the thrust is not accurate.
You misunderstood.
Again: If two contra rotating propellers are more efficient than a single propeller then they must generate more than double the thrust, if each propeller (of the two contra-rotating propellers) receives the same amount of power as the single propeller.
Or in other words (if one doesn't like the word double): If two contra rotating propellers are more efficient than a single propeller then they must generate more thrust than a single propeller if each propeller (of the two contra-rotating propellers) just receives 50% of the amount of power of the single propeller.
(Also, the sentences above just explain what efficiency means and don't claim anything.)
