Simon 12a esc - 3 stutter, 1 works!??
the enamel insulation on the wires can be a real PITA to work around. do you have some acetone? maybe dip the tips in acetone to soften the enamel and then dip them in alcohol to remove the acetone?
pavalige
I had the same problem with one of my Emax BLheli escs. I was testing the rotation of the esc and I accidentally shorted the power wires on the frame
pavalige
Soz I hadn't finished , cut a long story short I replaced the damaged esc and now alls good. The symptoms you describe are the same as my damaged esc
