I installed my Naza-M Lite and this is what I have so far.
ESCs manually calibrated using RX
Then everything wired channels 1-4/escs/voltage monitor/3 channel switch for flight modes
Confirmed through assistant that I have:
Sticks calibrated with motion in same direction as slider for all 4 channels range and centering seem fine.
Ail: left=left, right=right
Ele: up=left on slider, down=right on slider
Throttle: up=right on slider, down =left on slider
Yaw=left=left, right=right
Voltage monitor displays appropriate value
TX set to traditional
Gimbal set to off
GPS off
When I power up I get my typical esc happy tones, then I plug in the usb cable and I get a solid green LED. Everything looks good on the assistant readings but I cannot arm. I tried all of the stick combinations in the Naza manual. What am I missing? Thank you.
Gimbal set to off
GPS off
