Servoless Retract mounting hole spacing?
Carapau
Andy, given that you know the hole spacing (in the guff below the picture ie 24x28mm) why not just create your plate starting with M3 holes. If you need to make them larger you can simply drill out the original holes- the hard bit is getting the holes in the right place after all. I can't imagine that they would use M2.5 or even M2 for the holes but if in doubt get the holes made in the smaller size. Drilling out the holes is easy.
andythilo
Hi
That is not for the top holes, that's for the holes in the mounting plate. I need the spacing for the holes shown below:
helinor
Says hello from Norway
I have the same ones on my desk. The spacing looks to be 12.5x20mm.
Sent from my LT26w using Tapatalk
depewke
**EDIT**
Nevermind, I found the answer in a sister post to this one on Multi-Rotor UK. The size is m2 according to this thread:
http://www.multi-rotor.co.uk/index.php?topic=5760.0
Does anyone happen to know the thread size of the holes in question? I am planning to mount a sensor to detect when the gear is in the down position, and would like to mount a sensor holder using those mounting holes. It's definitely smaller than both m2.5 and 2-56 and I would prefer to not have to buy m2, m1.6, #1 and #0 screws just to figure this out if someone out there knows the thread size. Thanks!
