scratch built 8 - 900 w / naza M V2 hex copter
rubilac45
I;m having lots of trouble with this F C , I can't eliminate the error # 29 message , for one . It;s telling me the sticks are
not centered . So while tethered it lifts off nose first all the time , and needs me to push elevator / cyclic forward
at least 25 % for it to level off . Second , I cannot get it to go into calibration mode , to calibrate the compass .
Does anyone have a solution ? Weight and balance is as close to center as possible for trims to fine tune , BUT ?????
Motors are wired correct , rotation is correct , calibration for IMU says " ready " but seems like it has an aft CG , which it
doesn't . Is any familiar these problems or know how to change center of stick , without putting both batteries in front ?
I'm beginning to lose it !!!!!!!!!!
soler
Can you post some picture of your set up and possibly screen shots from the naza assistant showing the sticks at mid point
rubilac45
scratch built hex copter
I cannot edit , or post attachments etc . But after watching the great videos on this site , under product review tab , for Naza M V2 ,
I was able to center the sticks , and eliminate the error message , I can even get my hex copter into calibration mode .
So thanks , this a great site . I still have to dbl check all wires , motors , props , and ESC's for proper / uniform programming .
I'll be glad to send pics direct if you tell me how .
JJP
rubilac45@gmail.com
soler
JJP
rubilac45@gmail.com
Good to know its working now,
