Similar issues??
Hi Guys,
Just purchased an EVO/zenmuseNEX7 also and 3 x new 16,000mah batteries. Charging batteries to 100% but after about 4 and a half minutes hovering I notice the battery indicator on the FPV screen flashes. I then get flashing white lights (could be amber but they look white so I was worried it was IMU but it cannot be a coincidence that it flashes at the same time the battery indicator flashes can it??) It then flies another 1 minute, red flash and then lands itself (obviously i'm testing so I am only 1 metre of the ground) The resting voltage is then sometimes between 22.2 and 23.3V??? so more in the tank???
Manufacturer tells me 10-12 mins flight time on 16,000mah. I have changed the A2 settings to the following 'Set the landing voltage (2[SUP]nd[/SUP] warning) at 20.5, set the 1[SUP]st[/SUP] warning at 21. You should land at 21 normally or before the voltage starts to drop quickly'
After today's flight time of 5 minutes, I put the battery back on balance charge and it was at 13% and by the end of the charge it had put back about 6000mah??
Any thoughts on this.....
