divertom80
Just to show peeps that it is possible with the 5208 180T motors and an Alexmos 3 Axis board with 3S battery. This is a handheld system for MultiRotors
And I can't get canon 5D mkIII with 24-70 lens to work on identical setup
edit. I can set it up like this, always in horizontal position.. but would love to see that you do some tilt and to see how stabilization works when camera is at some angle...
Yap, I'm aware of that.. But I just cant seem to balance tilt axis like that with Canon 5D, it stay in level on horizontal, but it won't stay in place at any other angle (always goes back to horizontal)...
Would love to see someone correct balancing 1,7kg camera on that famoushobby gimbal.
I just saw freefly tutorial on balancing tilt axis and it also seems that Tabb didn't menage to balance the camera so it sit at any position, only horizontal
https://vimeo.com/album/2519626/video/73987812
Thats a pain, hope you get it sorted out. Cheers.
I watched that video and he mentioned getting the vertical balance right. You also need to adjust the up/down adjustments for the camera plate. Once you get the vertical balance done you should have some luck. If you havent tried that already of course. There are 5 balance points to get right includiing the panning ability.
Iscorama the video you posted is the first step of a two step process for tilt balance. The second video is not posted yet. That is where you do the vertical tilt adjustment. When done with all axis the camera should stay in any tilt/roll/pan location without moving with no power.
