This is an RC Carbon foldable Y6 with custom, foldable landing gear. The frame measures ~600 mm from rotor to rotor, and will accommodate up to 14" props (15" props will fit, but it's cutting it close). It has a dual lipo mount on the underside, is tall enough to fit a decent gimbal and camera system, and the ESCs and power distribution will all fit between the two centerplates (I will include a custom power distribution harness). The rail mounts on the landing gear are spaced for common gimbals (e.g., photohigher), and can be easily removed by pulling several cotter pins. When this frame first came out, I believe it was over $500 for the frame, plus an additional $200 for the landing gear. The only flaw on this particular frame is that one or two of the motor mounts have small stress marks; but, this does not affect the performance.
A good setup for this rig is:
Avroto M2814-11s motors
30 A ESCs
Dual or single 4s 5,000 mAh lipo
11x4.7 props
Small DSLR w/ gimbal
Asking $280 shipped (extra fees may apply if outside of USA)
PM if interested
30 A ESCs
11x4.7 props
PM if interested
