Is there any chance this could be a bad compass calibration? I had a similar result with a failed compass calibration. I had a good fix on the ground but after take off it would not stay in GPS mode and would revert to Alti.
Could you imagine (just setup my first WKM - not flown yet), that, when I get nothing else than green light indication from my led - this could happen, because it did no compass calibration yet? (It was raining the whole day)
and also - even if I have setup a working 3-mode switch, what turns the according field (GPS,ATTI,MANUAL) blue while moving in Wookong Assistant 2.0.2 - in the bottom line (black close to the blue and green status lights) of the WKM Assistant it shows only the MANUAL or ATTI position, but not GPS - all because I did not calibrate my compass??
DJI wiki says for LED green flashing - IMU signal lost, but when I remove the can bus plug from the IMU green light is flashing more rapidly than it does in my case.
Thx for help
Jan
P.S.: Sorry can't resist - everybody says DJI is so plug & play compared to MK for ex., but to be forced to interprete all problems through LED indications - no word about missing compass calibration in the assistant?? - not very user friendly?
