I currently use a Spektrum DX8 radio and up to now, 8 channels has just about been enough for my needs. I've just about completed a new build (coaxial octo with WKM) and definitely need more channels.
I dont theink the 9 channels offered by the DX9 will be enough so I'm limiting my decision between the Spektrum DX18 and Futaba 14 SG.
Although I'm obviously used to Spektrum radios, having done a little bit of research, I'm leaning towards the Futaba 14 SG with a R7008SB receiver. This set is listed around £425 on the net whereas the Spektrum DX18 is £525 with an AR9020 receiver.
Okay, so this is no where my confusion starts and I have to start making assumptions.
Firstly, the AR9020 is a nine channel receiver, so out of the box I would only have 9 channels? I'm assuming I would need to buy the X-Plus expansion module to use all 18 channels of the transmitter?
How about with the Futaba 14 SG/R7008SB set up? Could I connect the WKM via the S-Bus and then use the other standard outputs to control landing gear, lights, gimbal control etc. Can I mix S-Bus and standard outputs or is it one or another?
Sorry if these are dumb questions but I have no experience of futaba whatsoever.
