Putting together a Y6. I've built a few multi's but this is my first coaxial setup. After countless looking and researching for the correct motors I have made a choice and wanted to see if anyone had any input. I tried to research everything, but figured someone with real world experience may know. Got the proper frame, flight control, ESC's. Ready for Motor/Props and batteries. Ideally I will use Two 4s 5000mAh LiPo's ran in parallel, and would like to achieve at least 15min flight time hauling my camera & gimbal.
My Y6 is ~ 2.8kg AUW. I have selected the RC Tiger Motor MT2814-770kv to run with 11" CF Props. If my math is correct I have roughly 3.7kg of thrust at 50% throttle on these motors, which would be more than enough correct? NOW, I might be incorrect, but I assume that is what the math came out to when looking on the Tmotor website.
EDIT: I found the Tiger Motor MT2814-19 400kv to be much more efficient, cooler, and better motor. I can get it for the same price as the MT2814-770kv. Does anyone know if the 400kv will run on parallel 4s batteries?
eCalc shows my results but I am not clear as to if this is for just one battery or two. If I calculate the motor's thrust at 50% throttle I "believe" I am well in capacity for this setup if I run parallel. I have attached my ecalc sheet because many of you probably can read it better than I can. Thanks for any help
