R_Lefebvre
Arducopter Developer
What other systems could that be? Xaircraft?
It WAS a nice looking bird. As I look at the photo of it, it looks like the booms are square carbon fiber tubes which leads to a homebuilt as the most likely frame. I can't help but expect the FC to be DJI or one of the other FCs well known to be used on high end custom AP rigs.I came here because I figured you guys would be hot on the trail of figuring out the details.
I'm trying to figure out which frame that is. It's hard to say, but looks highly customized, possible home-built from a kit. Doesn't look like it's direct from any of the big players.
I was expecting to see a white GPS, but it appears to be black. Could be a 3DR GPS puck. Or several other brands, but it's not white. If it was Arducopter, I want the logs.
I blew it up in photoshop. One is higher. Even if I'm wrong and you're right.....OK then just figure out what frame mounts batteries offset OR higher.......I was simply trying to narrow down what frame it might be by visual clues. Does anybody know what frame uses either an offset or one higher than the other battery setup?Either the battery is higher than the other or one has been placed further forward than the other (more likely IMHO). More of an optical illusion.
http://www.infrontsports.com/news/2015/12/updated-statement-–-regarding-fis-alpine-ski-world-cup,-slalom-race,-on-22-december-2015/
"The initial technical report indicates a malfunction of the drone. According to the drone operating company, the most likely reason is a strong and unforeseen interference on the operating frequency, leading to limited operability. Detecting this, the pilot followed the official security procedure, purposely flying the drone as close as possible to the ground before releasing it. The aim was to destroy the drone, in order to prevent it from losing control."
That makes no sense at all to me. Anybody else?
"So, there was interference, and they lost control, but they could control it enough to get it close to the ground and then purposefully crash it? Doesn't make a lot of sense. "
Was this a near-flyaway in GPS mode, and the operator switched to full manual, brought the altitude down, and switched off the motors? I don't understand why you'd purposefully crash a copter you had manual control over. If you didn't have manual control, why not allow radio-failsafe Autoland? How did you do this "controlled crash" if you had no control? Just doesn't make sense.
I think it was a custom build. Just my two cents. Yep, that press release.....lol...what a crock.feng,
On my builds I can set battery trays at any height I want by using different stand off lengths. That could easily be the case here if it's a custom build and some lower component was so tall the battery mount needed to be higher. The boom tubes appear round using the visibility tape as a dimensional reference. The frame could be any number of brands that started out as a flat 8 and modified to X-8 by removing some arms. It's something I'll do to a Tarot flat 8 frame every chance I get.
I'm with Rob, the company press release was pure B.S.
The pilot was mute? He could have done what was right and just not done the shots they wanted refusing on the grounds of safety. That is what I would do. The pilot has his fingers on the controls, not the network. The pilot is the one who ultimately answers to the lawsuits that would arise. But then, I am a retired hobbyist with no greedy expectations of getting rich forgetting about the safety of others. Buck passing sucks.Let me add the copter-pilot flew exactly where the Italian TV was telling him to fly (the flying path was no accident), since the shot was all the same at a lot of racers before, chasing the racer from above (here you get the best view which path the racer took, also this view is always used in after-race analysis). So everyone (of the officials) knew how and where they are flying. So for the sake of a good show they (TV, world-cup officials, ...) risked this to get a nice view from above, but of course afterward the pilot only is the bad guy. A pilot never should have commercial thoughts in the background when flying or the voice of the int. broadcasting TV-company in his ear.
