Proper ESC sizing
For a perspective on my MR - AUW.... My Cinestar8 will be lift a GH3 on a 2 to 3 axis BG.
The motors will be Tiger MN4014 - 400KV.
Seems I read somewhere recently on MRF or somewhere else that oversized ESCs will reduce the system efficiency, heat up and lower my total MR flight time.
So should I swap out my 45A ESCs for 40A ESCs?
fltundra
Seems I read somewhere recently on MRF or somewhere else that over sized ESCs will reduce the system efficiency, heat up and lower my total MR flight time.
The max draw on that motor is 35 amps, if i were using those i would have 40 amp esc's for the extra headroom. I think you would be fine with 35's. I don' t think you can do much better than what you have, i don't think you will gain any by changing them.
