Hey guys,
First post here, so take it easy! I had a brainwave the other day and wanted to bounce some ideas off you guys.
I work in the underground mining industry. We run often run into problems where there's no way to explore/map out areas because they're too dangerous. I'm thinking multirotors could be a great solution to this problem. For example;
1. When equipment gets stuck while boring vertical tunnels, multirotors could be sent in to figure out what's going on (or to check where there's water inflow, etc etc).
2. Mines often abandon old workings and need to go back decades later. These areas are considered unsafe - you have to support the ground on your way in, which costs a TON of money. Multirotors could be sent out to scope out potential dangers.
3. Speaking of old workings, they're rarely surveyed properly. Multirotors could survey these, though I'm not sure how yet (GPS doesn't work underground... remember).
That's just scratching the surface. I think there would be several more applications underground. The question is; does the technology allow for this? I saw a post about obstacle avoidance, that would be a start. Could a multirotor autonomously explore areas without human input?
Either way, any input is appreciated. Thanks in advance.
