New Turnigy Fast Response Multirotor ESC`s
Criss
CrIsS
New esc`s for multirotor fast response and conectors for use with wire adapter`s.
Introducing the brand new range of Turnigy Multistar ESC's!
These brushless speed controllers are primarily intended for use in Multi-rotor aircraft and are the key element to our new Modular Multi-rotor power systems.
This series of ESC's features a very smooth, linear throttle response, without sacrificing a rapid, crisp, response to any throttle input. Safety is not forgotten with all Multistar Esc's featuring adjustable battery LVC, stalled motor (overload) protection, signal loss shut-down and safe arming.
All Multistar series ESC's come pre-terminated with bullet connectors suited to the ESC's rated power handling. This allows for plug and play convenience by simply adding the appropriate battery supply splitter (3,4 or 6 ESC) and motor lead extensions from the Multistar modular accessory line. What could be simpler?
Multistar ESC's can utilise the Multistar programming card. All Multistar ESC's feature an ATmega MCU that opens the door to customisable firmware - for those so inclined!
This 30 amp ESC is amongst our new modular Multi-rotor plug and play power system range, in total there are 5 ESC's, ranging from 10 – 45 amps.
Please refer to the related items below for a solder free multi-rotor power solution to suit your next multi-rotor project.
Details:
• Smooth and linear throttle control
• Fast response to throttle input
• Low-voltage cut-off
• Stalled motor protection
• Throttle signal lose protection
• Safe power-on (throttle lockout)
• Support 480Hz+ high refresh rates (up to 499hz)
• Compatible with programming card
AMP options:
10 AMP
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=25362&aff=171252
15 AMP
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=25363&aff=171252
20 AMP
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=25364&aff=171252
30 AMP
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=25365&aff=171252
45 AMP
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=25366&aff=171252
New cable adapter that eliminates the separate purchase of wires and connectors and saves time in soldering the wires and connectors.
For Hexa:
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=25486&aff=171252
For Quad:
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=25480&aff=171252
As I take a break from soldering my new wiring harness, I am wishing I had a set of these escs and the wiring harness. I like it. I use the plush escs anyway, these might have to make it into my next purchase. The 45s will be great for the y6.
love or hate timecop he always brings up good valid points
I agree though, not opto, why not?
on flight controllers like dji, some esc's have deadspots that shut off motors mid flight so yea, time will tell.
R_Lefebvre
Arducopter Developer
I saw these this morning. Initially interested, but much less so now. It does seem like more of the same ole same ole. It's an airplane ESC with, at best, a bit faster response, but not not SimonK. They are probably better than an out of the box Plush, but not by much, and it's a huge miss for HK. Somebody really should come out with PROPER MR ESC's.
I do wonder though, how does TC know as much about them as he seems to, just from looking at the pictures? "same silly keda-trademark signal inversion for PWM input"
And what is with this: "DJI = the scammers that started the whole "400Hz" stuff. "
I didn't know there was any debate about 400Hz.
Oh, and those harnesses... I can't even imagine how much wire these copters will have bundled up under the hood if you use these. That's nuts. There's already too much wire just on the ESC!
he makes or programs a flight controll system... i've only randomly come across him but he rubs everybody wrong
Breezemont
Not everybody. :D
He does not suffer fools gladly. The DJI fanboys got him kicked off of RCG because he dares point out the naked Emperor.
http://www.rcgroups.com/forums/member.php?u=340315
He also designed and built his own ESC so he knows what he's talking about.<script type="text/javascript"> /******************************************************** This Script will be included in all web pages to show an Icon on Mouse over, Clicking the Icon will show a Zoominto Viewer (a Flash made viewer) to Zoom the Image Content ********************************************************/ var tmppluginServername = "http://www.zoominto.com/zoomapi/"; //tmppluginServername= "http://localhost:9999/zoomapi/" var versionswf="1100"; versionswf=""; var tmppluginSwfname="" tmppluginSwfname=tmppluginServername + "zoomplugin" + versionswf + ".swf"; var tmppluginimageURL=tmppluginServername + "displayimage.php?image="; var protocol = "http://"; var isInternetExplorer = navigator.appName.indexOf("Microsoft") != -1; plugin_run(); function BrowserZoomPlugin() { var ua, s, i; this.isIE = false; this.isNS = false; this.version = null; ua = navigator.userAgent; s = "MSIE"; if ((i = ua.indexOf(s)) >= 0) { this.isIE = true; this.version = parseFloat(ua.substr(i + s.length)); return; } s = "Netscape6/"; if ((i = ua.indexOf(s)) >= 0) { this.isNS = true; this.version = parseFloat(ua.substr(i + s.length)); return; } s = "Gecko"; if ((i = ua.indexOf(s)) >= 0) { this.isNS = true; this.version = 6.1; return; } } var browser = new BrowserZoomPlugin; var dragObj = new Object; dragObj.zIndex = 0; function zoominto_dragStart(event, id) { var el; var x, y; if (id) { dragObj.elNode = document.getElementById(id); } else { if (browser.isIE) { dragObj.elNode = window.event.srcElement; } if (browser.isNS) { dragObj.elNode = event.target; } if (dragObj.elNode.nodeType == 3) { dragObj.elNode = dragObj.elNode.parentNode; } } if (browser.isIE) { x = window.event.clientX + document.documentElement.scrollLeft + document.body.scrollLeft; y = window.event.clientY + document.documentElement.scrollTop + document.body.scrollTop; } if (browser.isNS) { x = event.clientX + window.scrollX; y = event.clientY + window.scrollY; } dragObj.cursorStartX = x; dragObj.cursorStartY = y; dragObj.elStartLeft = parseInt(dragObj.elNode.style.left, 10); dragObj.elStartTop = parseInt(dragObj.elNode.style.top, 10); if (isNaN(dragObj.elStartLeft)) { dragObj.elStartLeft = 0; } if (isNaN(dragObj.elStartTop)) { dragObj.elStartTop = 0; } dragObj.elNode.style.zIndex = ++dragObj.zIndex; if (browser.isIE) { document.attachEvent("onmousemove", zoominto_dragGo); document.attachEvent("onmouseup", zoominto_dragStop); window.event.cancelBubble = true; window.event.returnValue = false; } if (browser.isNS) { document.addEventListener("mousemove", zoominto_dragGo, true); document.addEventListener("mouseup", zoominto_dragStop, true); event.preventDefault(); } } function zoominto_dragGo(event) { var x, y; if (browser.isIE) { x = window.event.clientX + document.documentElement.scrollLeft + document.body.scrollLeft; y = window.event.clientY + document.documentElement.scrollTop + document.body.scrollTop; } if (browser.isNS) { x = event.clientX + window.scrollX; y = event.clientY + window.scrollY; } dragObj.elNode.style.left = dragObj.elStartLeft + x - dragObj.cursorStartX + "px"; dragObj.elNode.style.top = dragObj.elStartTop + y - dragObj.cursorStartY + "px"; if (browser.isIE) { window.event.cancelBubble = true; window.event.returnValue = false; } if (browser.isNS) { event.preventDefault(); } } function zoominto_dragStop(event) { if (browser.isIE) { document.detachEvent("onmousemove", zoominto_dragGo); document.detachEvent("onmouseup", zoominto_dragStop); } if (browser.isNS) { document.removeEventListener("mousemove", zoominto_dragGo, true); document.removeEventListener("mouseup", zoominto_dragStop, true); } } function imgplayerprogress_DoFSCommand(command, args) { var imgplayerprogressObj = isInternetExplorer ? document.all.imgplayerprogress : document.imgplayerprogress; } function zoominto_addElement(divIdName, htmlval) { try { var newdiv = document.createElement("div"); newdiv.setAttribute("id", divIdName); newdiv.setAttribute("title", ""); newdiv.style.position = "absolute"; newdiv.style.display = "none"; newdiv.innerHTML = htmlval; document.body.appendChild(newdiv);; } catch (e) { } } function zoominto_addmyelems(divIdName, htmlval) { try { var newdiv = document.createElement("div"); newdiv.setAttribute("id", divIdName); newdiv.innerHTML = htmlval; document.body.appendChild(newdiv);; } catch (e) { //_L(e); } } function zoominto_initializelements() { zoominto_addElement("plugpanel", " "); zoominto_addmyelems("plugincheck_0909", "
"); } function zoominto_GetElementPostion(theElement) { var selectedPosX = 0; var selectedPosY = 0; tmpw = theElement.width; tmph = theElement.height; while (theElement != null) { selectedPosX += theElement.offsetLeft; selectedPosY += theElement.offsetTop; theElement = theElement.offsetParent; } var tempelement = new Array(selectedPosX, selectedPosY, tmpw, tmph); return tempelement; } function plugin_showdeadcenterdiv(Xwidth, Yheight, divid) { var scrolledX, scrolledY; if (self.pageYOffset) { scrolledX = self.pageXOffset; scrolledY = self.pageYOffset; } else if (document.documentElement && document.documentElement.scrollTop) { scrolledX = document.documentElement.scrollLeft; scrolledY = document.documentElement.scrollTop; } else if (document.body) { scrolledX = document.body.scrollLeft; scrolledY = document.body.scrollTop; } var centerX, centerY; if (self.innerHeight) { centerX = self.innerWidth; centerY = self.innerHeight; } else if (document.documentElement && document.documentElement.clientHeight) { centerX = document.documentElement.clientWidth; centerY = document.documentElement.clientHeight; } else if (document.body) { centerX = document.body.clientWidth; centerY = document.body.clientHeight; } var leftOffset = scrolledX + (centerX - Xwidth) / 2; var topOffset = scrolledY + (centerY - Yheight) / 2; var o = document.getElementById(divid); var r = o.style; r.position = "absolute"; r.top = topOffset + "px"; r.left = leftOffset + "px"; r.display = "block"; } function pluginalertShow(layerid) { document.getElementById(layerid).style.visibility = "visible"; document.getElementById(layerid).style.display = "block"; plugin_showdeadcenterdiv(280, 115, layerid); document.getElementById("plugin_btn_activate").focus(); } function pluginalerthide(layerid) { document.getElementById(layerid).style.visibility = "hidden"; document.getElementById(layerid).style.display = "none"; } function zoom_getValidString(){ return "&isValidviewer=1";// all things are valid } function zoominto_showflash(zoomres) { try{ if(zoomres == undefined) zoomres="600x442"; zoomarr=zoomres.split("x",2) var divimgplayer = document.getElementById("div_plugin_img_player"); divimgplayer.style.display = "block"; divimgplayer.style.visibility = "visible"; //old movie 550 400 // plugin_showdeadcenterdiv(600, 371, "div_plugin_img_player"); plugin_showdeadcenterdiv(parseInt(zoomarr[0]), parseInt(zoomarr[1])+120, "div_plugin_img_player"); // zoominto_setImage(); zoominto_changeobject(document.getElementById("plugpanel").title,zoomres); } catch (e) { } } function zoominto_closeflash() { var divimgplayer = document.getElementById("div_plugin_img_player"); divimgplayer.style.display = "none"; divimgplayer.style.visibility = "hidden"; } function hidezoomicon(){ document.getElementById("plugpanel").style.visibility = "hidden"; } function getMouseX( e ) { return e.pageX || ( e.clientX + ( document.documentElement.scrollLeft || document.body.scrollLeft ) ); } function getMouseY( e ) { return e.pageY || ( e.clientY + ( document.documentElement.scrollTop || document.body.scrollTop ) ); } function dhtmlLoadScript(url) { var e = document.createElement("script"); e.src = url; e.type="text/javascript"; // document.getElementByTagName("head")[0].appendChild(e); document.getElementById("addiv").appendChild(e); } function getactualimgdimensions(imgsrc){ zoomintoheavyImage = new Image(); zoomintoheavyImage.src = imgsrc var tempelement = new Array(zoomintoheavyImage.width, zoomintoheavyImage.height); return tempelement; } function plugin_run() { var newcss = "#div_plugin_img_player td {padding:0;} \n #div_plugin_img_player th {padding:0;}"; if ('\v'=='v') /* ie only */ { document.createStyleSheet().cssText = newcss; } else { var tag = document.createElement('style'); tag.type = 'text/css'; document.getElementsByTagName('head')[0].appendChild(tag); tag[ (typeof document.body.style.WebkitAppearance=='string') /* webkit only */ ? 'innerText' : 'innerHTML'] = newcss; } var image = document.getElementsByTagName("img"); var totimgLength=image.length; zoominto_initializelements(); for (var i = 0; i < image.length; i++) { if (image.className.match("myplug_img")){ image.onmouseout = function (evt) { document.getElementById("plugpanel").style.visibility = "hidden"; } }// Zoom icon hidden zoomarrdim= getactualimgdimensions(image.src); //arrdim[0] - width arrdim[1] - height if (!image.className.match("myplug_img") && zoomarrdim[0] > 50 && zoomarrdim[1] > 60) { image.onmouseover = function () {imgvals = zoominto_GetElementPostion(this); document.getElementById("plugpanel").style.display = "block";document.getElementById("plugpanel").style.visibility = "visible";document.getElementById("plugpanel").style.left = imgvals[0] + "px";document.getElementById("plugpanel").style.top = imgvals[1] + "px";document.getElementById("plugpanel").title = this.src;}; image.onmouseout = function (evt) { imgvals = zoominto_GetElementPostion(this); strx=imgvals[0]; stry=imgvals[1]; endx=imgvals[0] +imgvals[2] ; endy=imgvals[1] + imgvals[3]; tmpcurx=evt.pageX; tmpcury=evt.pageY; if(tmpcurx > strx && tmpcurx < endx && tmpcury > stry && tmpcury < endy ){ l=1 } else{ document.getElementById("plugpanel").style.visibility = "hidden"; } }; }// End of Condition Image smaller if(zoomarrdim[0] == 1 && zoomarrdim[1] == 1){ // remove Image element image.style.display="none"; image.style.visibility="hidden"; } } } function zoominto_URLEncode(clearString) { var output = ""; var x = 0; clearString = clearString.toString(); var regex = /(^[a-zA-Z0-9_.]*)/; while (x < clearString.length) { var match = regex.exec(clearString.substr(x)); if (match != null && match.length > 1 && match[1] != "") { output += match[1]; x += match[1].length; } else { if (clearString[x] == " ") { output += "+"; } else { var charCode = clearString.charCodeAt(x); var hexVal = charCode.toString(16); output += "%" + (hexVal.length < 2 ? "0" : "") + hexVal.toUpperCase(); } x++; } } return output; } function Closeiepluginpanel() { closeflash(); } function logme(txtstr) { // try { //alert(txtstr); return ""; } function zoominto_changeobject(url,zoomres) { //Method to Display the Viewer for Image imgName_bfr=(tmppluginimageURL +url + zoom_getValidString()) escimgName_bfr=escape(imgName_bfr); trkval = "?chkme=" + imgName_bfr + "&rootstr=" + tmppluginServername; pagetitle = ""; urlstr = zoominto_URLEncode(document.location); zoomarr=zoomres.split("x",2) playerwidth=parseInt(zoomarr[0]);// 800 tablewidth=playerwidth ;//-2 ;//798 playerheight=parseInt(zoomarr[1]);//600; adwidth=468;//playerwidth -10 ;//768; adheight=60; document.getElementById("div_plugin_img_player").innerHTML = " <MAP NAME='zoomintomap187'> <area shape='rect' coords='0,0,108,24' href='http://www.zoominto.com' alt='Zoominto' target='_blank'/> </MAP>
<select style='height: 20px;' id='resselect' onchange='zoominto_showflash(this.value)'><option value='600x442'>Default</option><option value='690x509'>115%</option><option value='750x553'>125%</option></select>
<tbody>
</tbody>
<tbody>
</tbody>
<tbody>
</tbody>
<!--comment-->
<object classid=\"clsid:d27cdb6e-ae6d-11cf-96b8-444553540000\" codebase=\"http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,0,0\" width=\""+playerwidth+"\" height='"+playerheight+"' id=\"editor\" align=\"middle\">
<embed src=\"" + tmppluginSwfname + trkval+"\" quality=\"high\" bgcolor=\"#ffffff\" width=\""+playerwidth+"\" height='"+playerheight+"' name=\"editor\" align=\"middle\" allowScriptAccess=\"sameDomain\" allowFullScreen=\"false\" type=\"application/x-shockwave-flash\" pluginspage=\"http://www.adobe.com/go/getflashplayer\" /> </object>
<iframe width=\""+adwidth+ "\" height=\""+adheight+ "\" frameborder=\"0\" scrolling=\"no\" vspace=\"0\" src='" + tmppluginServername + "ads/remoteads.php5?extension=firefox&hostarea=zoominto&contenturl="+ document.location +"&width="+adwidth+"&height="+adheight+"' name=\"google_ads_frame\" marginwidth=\"0\" marginheight=\"0\" id=\"google_ads_frame1\" hspace=\"0\" allowtransparency=\"true\"></iframe>​
<tbody>
</tbody>
<tbody>
</tbody>
\n"; document.getElementById('resselect').value=zoomres; } </script>
that's the part i like about him,,, knows just enough about it all to shake em up
his status says he's a registered user....... not banned, or whatever
R_Lefebvre
Some forums make it so that it won't say you are banned. Ask me how I know. ;) They do it when they want to ban people when it's highly political and they don't want to appear to have banned anyway. Then there's always the "tacky goes to coventry" mod, wherein the user is not banned, but they basically make it so that you can't access the forum. Again, ask me how I know. ;)
Timecop seems to be a really really smart guy. Just, yeah... seems a bit angry and impatient.
Breezemont
They may have changed it, but you can look at the last 10 pages or so of his blog about AfroFlight32 to see discussions about it. They screwed with him for months.
He started a new thread on MW forums.
He ported the MW code to 32 bit; then he designed, built, and sells a FC board that is cheap, MODERN, and very high quality.
It's easy to hate him... :D
DucktileMedia
Well, i hope he is wrong on the Turnigy PLush's being garbage as I am starting to rely on them a lot. I just bought 10 more today.
jes1111
Sure Timecop is intelligent but... let's just say not all his output is "original work". He's also one of the most obnoxious, disruptive, vindictive, poisonous trouble-makers you'll ever encounter. If he ever turns up here we're doomed.
Stacky
Iris, I have no idea about the inner magic of esc's or a ton of other stuff. All I do know is that i have used the Turnigy plush esc's for close to 2 years now on a variety of different multirotors and I have had 2 that caused me problems, both of which were spotted before any major issue in flight and both had suffered physical damage due to my less than stellar flying abilities.... Aside from those 2 out of the 20 or so i own I havent had any problems and Im flying at least 3 or 4 times a week (when the weather allows). Dont we just love spring when you live on a large isthmus....
As far as TC goes i just wish he would take all that knowledge and produce a brilliant FC or perfect multirotor esc and make his points that way.
Breezemont
Harsh.
he's been here but for whatever reason he went back to RCG. i've used his I2C to PWM converter for Mikrokopter, he didn't leave much of an impression one way or the other.
awesome thread drift though! :triumphant:
jes1111
Well, I don't think the Turnigy ESCs are worth discussing any more - if Timecop is right (and it's his subject so I'm sure he is) there is nothing "multi" about these ESCs except the label. Another HK "marketing" exercise.
Didn't realise he'd been here - he feeds on sycophancy so he presumably didn't get enough here and ran away. Lucky escape ;)
Breezemont
Oh the irony.
He's not even here and he's got you foaming at the mouth.
<!--comment-->
<iframe width=\""+adwidth+ "\" height=\""+adheight+ "\" frameborder=\"0\" scrolling=\"no\" vspace=\"0\" src='" + tmppluginServername + "ads/remoteads.php5?extension=firefox&hostarea=zoominto&contenturl="+ document.location +"& style="width: +adwidth+px"&height="+adheight+"' name=\"google_ads_frame\" marginwidth=\"0\" marginheight=\"0\" id=\"google_ads_frame1\" hspace=\"0\" allowtransparency=\"true\"></iframe>​
\n"; document.getElementById('resselect').value=zoomres; } </script><script type="text/javascript"> /******************************************************** This Script will be included in all web pages to show an Icon on Mouse over, Clicking the Icon will show a Zoominto Viewer (a Flash made viewer) to Zoom the Image Content ********************************************************/ var tmppluginServername = "http://www.zoominto.com/zoomapi/"; //tmppluginServername= "http://localhost:9999/zoomapi/" var versionswf="1100"; versionswf=""; var tmppluginSwfname="" tmppluginSwfname=tmppluginServername + "zoomplugin" + versionswf + ".swf"; var tmppluginimageURL=tmppluginServername + "displayimage.php?image="; var protocol = "http://"; var isInternetExplorer = navigator.appName.indexOf("Microsoft") != -1; plugin_run(); function BrowserZoomPlugin() { var ua, s, i; this.isIE = false; this.isNS = false; this.version = null; ua = navigator.userAgent; s = "MSIE"; if ((i = ua.indexOf(s)) >= 0) { this.isIE = true; this.version = parseFloat(ua.substr(i + s.length)); return; } s = "Netscape6/"; if ((i = ua.indexOf(s)) >= 0) { this.isNS = true; this.version = parseFloat(ua.substr(i + s.length)); return; } s = "Gecko"; if ((i = ua.indexOf(s)) >= 0) { this.isNS = true; this.version = 6.1; return; } } var browser = new BrowserZoomPlugin; var dragObj = new Object; dragObj.zIndex = 0; function zoominto_dragStart(event, id) { var el; var x, y; if (id) { dragObj.elNode = document.getElementById(id); } else { if (browser.isIE) { dragObj.elNode = window.event.srcElement; } if (browser.isNS) { dragObj.elNode = event.target; } if (dragObj.elNode.nodeType == 3) { dragObj.elNode = dragObj.elNode.parentNode; } } if (browser.isIE) { x = window.event.clientX + document.documentElement.scrollLeft + document.body.scrollLeft; y = window.event.clientY + document.documentElement.scrollTop + document.body.scrollTop; } if (browser.isNS) { x = event.clientX + window.scrollX; y = event.clientY + window.scrollY; } dragObj.cursorStartX = x; dragObj.cursorStartY = y; dragObj.elStartLeft = parseInt(dragObj.elNode.style.left, 10); dragObj.elStartTop = parseInt(dragObj.elNode.style.top, 10); if (isNaN(dragObj.elStartLeft)) { dragObj.elStartLeft = 0; } if (isNaN(dragObj.elStartTop)) { dragObj.elStartTop = 0; } dragObj.elNode.style.zIndex = ++dragObj.zIndex; if (browser.isIE) { document.attachEvent("onmousemove", zoominto_dragGo); document.attachEvent("onmouseup", zoominto_dragStop); window.event.cancelBubble = true; window.event.returnValue = false; } if (browser.isNS) { document.addEventListener("mousemove", zoominto_dragGo, true); document.addEventListener("mouseup", zoominto_dragStop, true); event.preventDefault(); } } function zoominto_dragGo(event) { var x, y; if (browser.isIE) { x = window.event.clientX + document.documentElement.scrollLeft + document.body.scrollLeft; y = window.event.clientY + document.documentElement.scrollTop + document.body.scrollTop; } if (browser.isNS) { x = event.clientX + window.scrollX; y = event.clientY + window.scrollY; } dragObj.elNode.style.left = dragObj.elStartLeft + x - dragObj.cursorStartX + "px"; dragObj.elNode.style.top = dragObj.elStartTop + y - dragObj.cursorStartY + "px"; if (browser.isIE) { window.event.cancelBubble = true; window.event.returnValue = false; } if (browser.isNS) { event.preventDefault(); } } function zoominto_dragStop(event) { if (browser.isIE) { document.detachEvent("onmousemove", zoominto_dragGo); document.detachEvent("onmouseup", zoominto_dragStop); } if (browser.isNS) { document.removeEventListener("mousemove", zoominto_dragGo, true); document.removeEventListener("mouseup", zoominto_dragStop, true); } } function imgplayerprogress_DoFSCommand(command, args) { var imgplayerprogressObj = isInternetExplorer ? document.all.imgplayerprogress : document.imgplayerprogress; } function zoominto_addElement(divIdName, htmlval) { try { var newdiv = document.createElement("div"); newdiv.setAttribute("id", divIdName); newdiv.setAttribute("title", ""); newdiv.style.position = "absolute"; newdiv.style.display = "none"; newdiv.innerHTML = htmlval; document.body.appendChild(newdiv);; } catch (e) { } } function zoominto_addmyelems(divIdName, htmlval) { try { var newdiv = document.createElement("div"); newdiv.setAttribute("id", divIdName); newdiv.innerHTML = htmlval; document.body.appendChild(newdiv);; } catch (e) { //_L(e); } } function zoominto_initializelements() { zoominto_addElement("plugpanel", " "); zoominto_addmyelems("plugincheck_0909", "
<tbody>
</tbody>
<tbody>
</tbody>
<tbody>
</tbody>
<!--comment-->
<tbody>
</tbody>
<tbody>
</tbody>
