Yeah, there's really only 2 ways to do AP, shoot and pray/trial and error or have a 2nd person. On production shoots the DP usually wants to be part of it anyways. So it could be really neat to actually let them have full control of the camera. Its not hard at all, they only have to understand that the camera needs to be left alone if the pilot has an orientation panic. The way we do it, is to leave it alone if it is way off coming in for landing or snap it back to its correct orientation quickly if it is less than 90deg off. It can be so damn hard to focus on the heli when that gimbal is spinning in circles. I think it would be really cool to actually have those retracts just for this reason. Less to confuse the pilot. but this isnt what the thread is about.
Don't you just fly in simple mode? Then orientation doesn't matter at all.
Yep - no video transmitter. The 802.11n wi-fi standard is 5GHz, so no conflict with 2.4GHz. Although I gather (I haven't tested) that RC and 2.4GHz wi-fi can coexist if you have sufficient space between aerials. The 5GHz band is also much less over-crowded than 2.4GHz and has better rejection of interference.
Interestingly, "Live view" (both Canon and Nikon) is not a video signal at all: it's actually a stream of lo-res jpegs - easier on the bandwidth.
Ah, ok, that should be fine then. I do have a 5.8GHz FPV system, but then this would become much less necessary. I had thought it would be handy for the pilot to still have a small, simple, FPV cam, and the camera operator uses the main cam. Just for basic things like "am I above that tree or not".
I hadn't considered the EOS live-view when considering the Nex5, so thanks for pointing it out. That is a real game-changer. Sony doesn't have anything similar?
So what additional equipment is required to do this? Just a wireless router?
If you're flying with regular RC sticks, yes - maybe. But the next step forwards is "tablet control" (with thumb-operated joysticks either side of a touch-screen). Combined with reliable position hold and "moveable waypoint" flying, single operator would be a cinch.
We have this working now. It's pretty cool. You basically have a laptop in your hand showing Google Earth imagery, double-tap, and it flies there. Simple as that. Can also be done on a laptop obvoiusly, which would also allow simple multi-tasking between the GCS and the Live View software. You could even potentially set up an extended screen with the instance of GCS and the Camera software running on each. Now that would be perfect. IMO, that's actually the way to go because at this point we still need the laptop running in addition to the tablet anyway. The tablet is just sort of cool-factor at this point, I think. The reason is the laptop is basically a relay. Tablet-->AdHoc Wifi-->Laptop-->900MHz Radio Modem-->Copter
