New Release: Align APS-M Multicopter Control Unit
SleepyC
www.AirHeadMedia.com
Brand new APS-M multicopter control unit with superior performance through cutting edge IT technologies, utilizing high precision sensors and modern system control subroutines. Support quad(4), hex(6), and octo(8) rotors. Flight modes include attitude, GPS speed, GPS angular, intelligent, and manual. In addition, it features GoHome failsafe, low voltage failsafe (through LED indicator and auto GoHome), OSD signal output, gimbal control, fix-point survey functions.
Compatible with PC and Bluetooth interface, could be easily adjust flight parameter and update firmware at any time.
Focus Points
  • Brand new APS-M multicoptor control unit with higher performance, precision sensors and superior reliability platform.
  • APS-M supports 4, 6, and 8 rotors multicopters, with flight modes such as Manual, Attitude, GPS (angular), GPS (speed), and Intelligent.
  • APS-M provides OSD output function to output various flight parameters and with waypoint modes :
    • Patrol (ground station)
    • Commanded return home (Go Home)
    • Automatic loss-of-signal return home
  • Compatible with PC and Bluetooth interface, could be easily adjust flight parameter and update firmware at any time.
  • Also fully support with Futaba, Spectrum and JR S. BUS/S.BUS and DSM2/DSMX/DSMJ/DMSS system.
APS-M Specification
Input voltage
DC4.5V~8.4V
Operating current consumption
<250mA@ 4.8V
Operating Frequency
400Hz
Operating Temperature
-20° ~ 65°C(-4° ~ 149 °F)
Hovering Precision (Depending on satellite status)
Horizontal ±1m
Vertical ±1m
Highest flight speed
Horizontal 15m/sec
Vertical 6m/sec
Maximum Altitude Restriction
700m(1640ft) above the takeoff point
Maximum angular speed
ALE 115° /sec
ELE 115° /sec,
RUD 145° /sec
Maximum Tilting angle
30 degrees
Supports External Peripherals
G2 / G3 Gimbal、OSD+FPV Video Transmitter
Supports multicopter configurations
4 rotors +, 4 rotors X, 6 rotors +, 6 rotors X
8 rotors +, 8 rotors X
Dimension
49x34.3x20mm
For more info: Align.com
Carapau
I wonder if this will be similar in performance to Align's flybarless controllers- hopefully not!
synrg
SleepyC are you planning on doing a review? Would like to know your thoughts on how APSM performs compared to SuperX.
SleepyC
Hey guys, we just got the new version of the site up and running and believe me we will be doing a LOT more work with manufacturers, reviews, press releases you will find it here.
