1001 Copters
hi,
I'm proposing a plug N' Play Epi OSD ground station in my shop:
Evrybody knows the famous EPI OSD that alows to see flight data on screen:
You can use this board on your MK or on the ground.
There are several advantages to use it on the ground:
- less electronic card on the MK, less cables, less interferences due to alimentation cables
- You can record your video without the OSD infos
- in case of video failure, you still have the OSD data on screen
- in case of crash, it's one costtly component thats won't break or be subject to glitches
This EPI station is composed by an EPI OSD and two XBE Pro modules. You can choose the XBEE pro module you want: 2.4Ghz or 900mhz (note the 2.4Ghz module doesn't intefer with your 2.4 radio )
You can also choose between two power connectors: JST or XT-60
This product is only available on order.
