Thanks for your reply.
Is the Cinestar 6 bigger than the AD6? Will the Cinestar 6 perform better in wind?
I already bought the dji wkm flight control and avrotor motors.
Regards
Xavier
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
I have both frames and have flown them both with Mikrokopter flight controller and WKM. For APV work there's no contest the Cinestar wins with it's camera mount isolation system, you won't see any jello in the video regardless of the camera and gimbal you use. I have a Photohigher AV130 on both and I can get better video using the CS than I can with the Droidworx, both using the same size motors. The difference is it's a little easier to get good flight stability on the Droidworx than the Cinestar using the WKM, but not by much, previous posts have been spot on regarding the how the WKM handles large frames in the wind. It is possible to tune the WKM to fly quite well on the Cinestar but the setup needed to do that will limit the carrying capacity of the frame, don't expect to be able to fly a RED using the WKM on the CS. You can't do it with the AD6 either more because it isn't big enough.
The CS is substantially larger than the AD6 but easier to break it down and pack it for transport if that is what you will be doing with it. The AD6 is more suited to being put into a large case fully assembled, or partially assembled with the landing gear/camera mount removed.
If the quality of the video recording is the driving factor in your purchase you will be better off with the Cinestar although you may need to rethink your choice of flight controller to get the best performance from either frame in all conditions.
