Hello guys
I need some help with mission planner
Settings with de qr x350 pro mostly about the compass.
Its external below the right rear arm on the landings leg.
I updated the quad to firmware 1.7
And downloaded the factory parameters
But under compass tab in mission planner it set on 180degrees yaw
But when you lay a imationary compass on top of the quad the arm and the leg is located at 135 degrees.
Wat doe you guys got on this tab in mission planner with this quad?
