Im planning to install a gopro on F450s lowerframe extended tab and the VU/VSENS unit on the other/rear extended tab. battery will be mounted on the upper frame. Question is based on the naza assembly manual 1st sentence on the VU box indicated not to mount it on any other electronics... would it hurt if i double sided tape my reciever beside the VU or if i place the VU under the lower frame (so i can see the LEDs in daylight) right below the reciever assuming that i will place the reciever on the center of the extended tab? thanks....
