Greetings,
I have a Naza V2 setup and working, including failsafe / RTL. I am using a Spektrum DX6i and only have 2 position switches, so have set my primary switch to toggle between GPS and Atti flight modes, with a custom mix to activate failsafe on another switch. All of this works except I noticed that if I want to regain control after switching failsafe on I can't simply switch failsafe off, I have to switch failsafe off as well as toggle the mode switch from GPS to Atti before I get back control. Is this normal, or is it because I only have a two way switch for each mode?
I'm going to try reprogramming so that GPS and failsafe modes are both on the same switch, with the mix on the other switch set to toggle Atti mode. I haven't had the chance to test this yet to see if it makes any difference.
Thanks,
Matt
Thanks,
Matt
