Beware, this is a half cocked response from me but I just had a quick look at the screenshots in post 8 and the comparison file PDF and given everything else you've said you've done, I suspect your problems could lie in using "-AIL/ELE/THR/RUD" rather than "AIL/ELE/THR/RUD". I believe the makes it a conditioned input and as it doesn't appear as though your comparison pdf includes all the settings that could be affecting your inputs, it's hard to determine what conditions you're applying to the stick movements. The comparison PDF appears to be using conditioned inputs on both models.
Have you tried setting up a totally and completely fresh model using the instructions above rather than trying to modify someone else's file? Start fresh using only the values you need for a basic setup instead of inheriting other peoples mods.
I see other glaring differences in the setup you're trying to use to what I would use and find to be tried and tested. For example your tx failsafe is different.
Start again with a totally clean model (or try one final time if you've already started using a 'blank canvas'), follow the instructions above that TahoeTim posted from the other thread and keep checking in the assistant as you go through that everything is working as expected. Double check your stick movements result in the assistant showing travel of 1000 to -1000 on the corresponding channels and report back!
