econfly
For most uses it happens automatically before takeoff. In GPS mode wait for slow blinking green on the LED before takeoff. It will then mark the takeoff point as the home point. From page 27 of the manual:
			The home point mentioned here is the same home point of enhanced Fail-Safe. There are two ways to record them: Manually and Automatically:
- Automatically: Before takeoff, the current position of the multi-rotor will be saved as home point by MC automatically when you push the throttle stick for the first time after 6 or more GPS satellites have been found ( blinks once or no blinking) for 8 seconds.
- Manually: When 6 or more GPS satellites are found ( blinks once or no blinking), you can toggle the X2 channel switch between (to a 3-position switch) Course Lock and Home Lock or (to a 2-position switch) OFF and Home Lock position quickly 3 to 5 times to record the current position of the multi-rotor as the new home point. And LED will blink quickly if recording is successful.
