Hey folks,
We've recently got an F450 with a NAZA M controller to experiment with GPS position hold, but I'm coming up against a strange issue. About 50% of the time, the controller boots up and detects a small amount of right aileron input, which is resulting in a drift to the right. If I land, reboot the unit and go again, all is well and it's solid as a rock. Has anyone else had this happen?
In the assistant software, this is easy to see, even after performing a calibration with all subtrims and tx trims set to zero. I can calibrate it, it says the aileron is set correctly, however when I reboot the unit, sometimes it shows a small amount of right aileron input. If I reboot it and connect it again, it's back in the center again
I know it's not the transmitter pot, because I have other equipment that uses visual representation of the tx output and it's perfect in there.
I know it's not the receiver, because it came out of an EDF jet that was flying perfectly right before I removed it to fly the F450. I've also briefly tried another receiver and got exactly the same results.
I know it's not CG, because I've gone so far as balancing it on 2 sharp points and using a builder's spirit level before doing some test flights.
My props are APC E props and are both blade and hub balanced using a Dubro balancer, so it's not vibes. We've got a GoPro stuck directly to the bottom of the frame and have virtually zero jello, even in 60FPS in full sunlight, so it's about as good as it gets without tape balancing the motors with a spectrum analyser (which I *am* going to do eventually anyway).
But all of those things are redundant anyway, because if I reboot the unit and fly again, it locks absolutely perfectly and does not drift.
I've done a search on here and it seems a lot of people have experienced a drift to the right, but everyone seems to have just been happy to either tilt the MC when they mount it, or just put some trim in to counter it. I'd rather not do either, because half the time it flies and locks position perfectly!
