Hello all,
I am building a Tarot 810 Multi rotor and using a DJI Wookong M autopilot
My radio is a Futaba T8FG with a RX R6208SB
My ESC's are 30 A Wobbywing Platinum pro OPTO (used a Wobbywing program
box to set them up) did one at time using powered RX alone
Brake - Off
Battery Type - NiMH
Cutoff - soft
Low Voltage -
Low
Start Mode- Normal
Advanced timing - 15
Governor - Off
PPM Freq.
- 12 KHz
Lipo Cells - 6
Then I performed the throttle range setting same way, one at time...I have a problem as I cannot
hear the low pitch sounds so it was a "hope for the best" type deal ( I did
reverse the Futaba throttle channel) so turned radio with stick up and moved
down in the 2 seconds.
I finished all connections and downloaded the DJI WKM Assistant and
driver.
I had a Phantom before so I am kind of familiar with it.
My questions:
1- Selected Tradition TX type on DJI Assistant (I know I could use one single cable aith S-Bus, just trying old fashion first)
2- Did the TX calibration, next I went to check if the rotation of motors
were correct (I had done that one by one while working with the ESC)...first
clicking on M1, M2... I had no response, so I went to advanced settings and set
all motors to 100%, click on M1 and it turns briefly...the M2,3,4,5,6, I get
NOTHING.
All connections are correct, what could be wrong?
Thanks for any help!
Ed
Brake - Off
Battery Type - NiMH
Cutoff - soft
Low Voltage -
Low
Start Mode- Normal
Governor - Off
PPM Freq.
- 12 KHz
Lipo Cells - 6
driver.
My questions:
NOTHING.
Ed
