matwelli
Interesting discussion.
Definately think the keeping it all compact is the way forward, current quad design has the cameras up close to the centre line, and i am playing with a body design thats about 50mm thick, and 800mm overall diameter, with radius edges it should not be two bad in the wind, and the long "chord" (its a flat plate in the air, acts like a simple wing) "should" help resist pitching moments.
My question for those that are knoweldgeable is this.
Efficiency goes up when prop diameter/area is increased and RPM's drop. Current trends seem to be going from 10" to 12" and KV's down from 900's to 600's.
If the T580 hype is anything to believe (and there are some crediable testers) the lower kv/bigger prop certainly seems to give a 20% efficiency gain.
Now...if the wind is primarily acting on the bits that stick out, and we can tidy up our designs, and largely on the swept area of the props...... would a higher RPM, less efficient, smaller prop diameter/area actually be better in the wind ?
The anology to me is the big prop/low kv setup are "treading air" to stay up, the small diameter/high kv, and doing it by standing on colums of fast moving air
Thoughts ?
Second thought, would a ducted prop setup be less affected by the wind ? as the wind would have no direct access to the prop surface ? the consideration would be the intake side to make sure if the multirotor pitches back, the prop dosent starve as the intake will be in a wind shaddow.
Thoughts ?
