dedzyyy
Hi, I'm having trouble with my DIY build. I have 100% noob and I've built a drone for film making using:
F450 frame,
Naza Lite,
GPS module,
Emax Simonk Series 20amp ESCs,
Sunnysky Angel A2212 980K motors
Turnigy 9X
When idling (i.e. on the ground before take off) the motors don't seem to rotate at the same speed and want to flip the quad when I try to go up. This happens when I try to take off aggressively, and when I try a bit more carefully.
When I go left with the stick the right side of the drone stays faster, and vice versa.
I've now set my Idle Speed to High, from Recommended following some advice I've seen on forums.
All the ESCs appear to be calibrated fine.
The props are definitely on the right way and the motors are spinning the right way.
Can anyone help please?
F450 frame,
Naza Lite,
GPS module,
Turnigy 9X
