aerialdroning
Hi all,
We fly with an S900 and get flawless video results.
I am about to built an 450 size x8 craft and wanted to use motor dampers similar to my s900.
Have found something that will do the job from Tarot.
http://www.foxtechfpv.com/tarot-Φ16mm-suspended-motor-seatblack-p-1664.html
However, these will work for the top mounted motors, but for the bottom mounted motors I'm not sure what to do, here's why:
The damper system works because of the separation created between the motor and the arm when the blades create lift. However, this won't be the case with the bottom motors. Yes there will be rubber there but the motor lift won't cause any separation, but rather it will compress the dampers into the arms...
Has anyone else here built an X8 using motor dampers? Maybe you'd have a few ideas?
Other comments also welcome.
Cheers.
Aaron
Cheers.
Aaron
