Well, why else would you do it? The dihedral won't come in to effect unless the controller has already failed to stabilize the craft.
It may actually make it worse in some conditions. If for example a strong wind hits from the side then the effect of that would be first seen on the upward tilted side which would then have an upwards component added to the force which the controller has then to overcome. I have always come to the conclusion through many tests, that the more vertically aligned the motors are the better it is with Quads.
The other stuff does not interest me because the more motors you have the less energy efficient it is, coupled with multiple failure points and expense.
The relationship between the center of mass and the aerodynamic center of lift can produce a natural stability if these two points are centered above one another and not too far apart vertically. As the two come together then the craft will become more sensitive to response outputs and require less energy to stay level. Too far apart and the model will sway about during lateral accelerations because the motors have to work harder to maintain level flight due to the moment arm of the forces involved.
The reality of supporting a gimbal underneath means that the ideal situation has to be compromised slightly. When the camera is below it is easier to maintain constant Z axis inertial loads and with the front mounted camera then the yaw inertia is higher but the pitch/roll inertial is less but only in the roll axis.(bad unless very light but can be partially overcome with some interesting asymmetric motor layouts) One element is clear and that is that the weight of the entire gimbal assy. needs to be as light as possible if you want inherent stability incorporated into the basic design.
Asymmetric motor layouts for quads do have some advantages but to work properly require changes to the FC algorithm. Available for WKM. MK and some others.
There are some quite compelling reasons why a tri-copter is the best option. With the same development that quads have had they could have become the way to go. Interesting that DJI never supported that Idea.
