DiaLFonZo
Hi All,
We are, at Lynxmotion, very proud and exited to introduce a new UAV / Drones flight controller born from a partnership between the well known FlyingEinstein and Lynxmotion team. We focused on many things on that project:
The Press Release:
RobotShop Continues its Expansion in the UAV Market by Acquiring FlyingEinstein’s Technology
- Have all the available and up to date hardware MultiWii support
- Mount all that hardware on the smallest possible size format
- Provide an easy to use Software Updating Tool
- Integrate protection to the bare PCB
What's Included:
Overview & Size:
BETA - Weights:
Quadrino Nano - Case + PCB + Screws + Dampers + GPS Antenna + Wiring Harnesses + 3M Mount - 64.22g
Quadrino Nano - Case - 11.62g
Quadrino Nano - Wiring Harnesses - 6.72g
Quadrino Nano - GPS Antenna - 29.12g
Quadrino Nano - 3M Mount - 0.82g
Quadrino Nano - PCB - 11.88g
The Press Release:
After many long months of work around those constraints, we are ready to show what we did for you.
The Lynxmotion Quadrino Nano Flight Controller is available on RobotShop and Lynxmotion :
(Lynxmotion Website)
(RobotShop Website)
Pre-Order price of $99.99 (normal price of $149.99)
Specifications:The Lynxmotion Quadrino Nano Flight Controller is available on RobotShop and Lynxmotion :
(RobotShop Website)
- ATmega 2560 (256Kb flash @ 16MHz) Processor
- Compact, six layer PCB design
- Mounting options: 3M double sided adhesive foam or screws
- Vibration dampening mounted PCB
- Arduino bootloader making DIY / hacking projects possible
- Onboard micro-USB connection / programming port
- Invensense MPU9150 sensor chip which includes:
- 3 Axis Gyroscope
- 3 Axis Accelerometer
- 3 Axis Magnetometer
- MS5611 Barometer with foam cover
- Latest Venus838FLPx 50Hz GPS chipset with external antenna (SMA connector)
- 50Hz GPS update rate
- NEMA serial output for OSD (On-screen display)
- Motor port with eight speed controller outputs
- Radio port with eight radio channels inputs
- use all four AUX inputs
- Two free serial ports (use for SBUS and/or Bluetooth or 3DR radio links)
- Three I2C ports, of which two are 3.3V and one is 5V
- 0.96” OLED port on-board
- Spektrum R/C receiver port
- Servo port with five outputs
- 2x10 I/0 connector expansion port
- LIPO alarm port and LED indicator
What's Included:
- 1x Lynxmotion Quadrino Nano PCB (assembled)
- 1x Dark “smoked” transparent case with damping via rubber grommets for PCB
- 1x GPS Antenna SMA with 15cm cable
- 1x Radio connection wiring harness
- 1x Motor controller wiring harness
- 1x Micro USB data cable
- 4x 4-40 x 0.75" screws (for mounting the case to a frame via holes)
- 4x 4-40 Nylon Lock Nuts (for mounting the case to a frame via holes)
- 1x 3M double side adhesive Foam (for direct mounting to a frame)
Overview & Size:
BETA - Weights:
