LK24-BT + CAN-HUB + A2 - Where?
Dave_EP
I want to add the LK24-BT to my S900 that has no free Can-Bus ports.
I have a DJI Can-Hub but wondered where is the best place to plug the hub in the system so I can add the LK24-BT and have it work.
Carapau
Hi Dave, the link needs to be plugged into Can 2 so you can place the hub anywhere on Can 2 and then what ever else you need can then plug into the hub. The joy of the canbus is that you can basically plug in any component to any available spot and it works. On the WKG there was just one Canbus so it really didn't matter but to improve data rates, DJI introduced a second Canbus on the A2. The critical thing here is to make sure the right components are connected to the right canbus.
Dave_EP
Thanks Angus. Going to fit this one piece at a time and flight test just as soon as the wind drops!
Almost called in on you a couple of days ago when passing Scotch Corner but thought it was a bit short notice!
