BumbleBeeTuna
Yeah the DJI settings are fine if you are flying line-of-sight and you can see that flashing light but I don't want that anywhere in my view since I use an OSD regardless. IOSD is ok, I use Eagle Tree everything and they rule as far as I'm concerned.
I don't fly an F550 anymore, I've had several since then but right now I'm flying basically what you have. I have a 30" hexa with Sunnsky 700kv 28 size motors running on 5S, total weight with batteries is around 8lbs. I can squeeze about 15 minutes out of these crappy Zippy Compact packs but I should get 20 minutes. I'm only getting about 4700mah out of 7400mah advertised on the packs. I'm probably going to go for the Turnigy Nanos as they seem to have good reivews across the board. The GenAce are expensive.
I like carbon fiber blades for 2 reasons, they are stiff and they are light. You don't want any flex in your blades or you are losing efficiency. If you can't go any bigger for sure go to multiple blades. The fewer the blades the better though but there's only so much room also. The P-51 used to have 2 blades, when they got the big monster 1500hp motors they went to 4 blades because otherwise they'd need 15 foot blades for a 2 blade setup to get the same thrust...soometimes you just run out of space.
Same here on the Nano's, heard they have been doing pretty good. I'm looking to pick up at least 2 more sets of batteries to run parallel, you got me thinking now on the nano's lol. Makes sense with the p-51 4 blade setup, im running 4014-380kv motors and i have plenty of grunt to spare. i found these http://www.ebay.com/itm/1-Set-Carbo...Control_Parts_Accessories&hash=item2c8af89ebd that iwas thinking about trying out with my triple prop setup because the dji ones are super soft! i think in some of my pics, you can see the blades actually flexing. if i go single prop, i was looking at these http://www.aliexpress.com/store/pro...-CCW-15inch-TM-15x5-CF/727137_1481341735.html but man, they're so expensive!
