Learning FPV with an Mk is actually pretty easy especially if you have Navi and GPS. What I did the first couple of times was setup a waypoint route that made a circle around a large open field (the RC Heli club flying field) with the first waypoint close to the takeoff point with a fairly long delay before moving to the next. Get the MK and FPV gear all setup, load in the GPS waypoints, take off normally, set altitude hold then start the waypoints. While the MK is loitering at the first waypoint get the goggles down over your eyes and go along for the ride. The first time you'll be a bit nervous but the Mk will be driving so just go along for the ride and enjoy the view, when you get to the last waypoint which should be near to the takeoff point, hit position hold and take the goggles off. Once you get reoriented you can land the MK.
Keep doing the same routine but add more interaction on each flight, the second time, try using yaw to keep the view pointed in the direction the Mk is moving while on the GPS route. The next time when the MK gets to the final waypoint, you could try landing with the goggles on. The goal is to get used to the perspective and controlling the MK with minimal risk.
If you just want to dive in head first and go for gold then either a Gaui 330X or a low budget KK quad would be a better choice to start with. I did my first FPV as I described above with the MK then when I felt I was ready I swapped the gear over to a Hoverfly quad and did the full flight. Even with the prior practice on the MK that first "solo" on the Hoverfly I was pretty nervous and a bit overwhelmed but it worked out fine. Another point about the MK, if you finally get to the point where you're flying FPV without GPS assistance and you get disoriented as to where you are you can always hit come home and let it find its own way back to the starting point.
Have fun and make sure to record the video off the downlink for later review, it's always interesting to watch it after the fact and see that what felt like a half hour of flying through the goggles was actually only a few minutes.
