KK Flight Controller KK 2.1HC Yaw position problem
JDFelosi
For some reason my quad continually rotates CW slowly, if i trim it out i can no longer arm/disarm, is there a way to fix it in programming of the FC?
Quas
Check your motor layout and wires. Mine was doing this earlier till I realized I was off on the connectors. Hooked the motors to the correct pins and fixed.
jbrumberg
What kind of frame, boom, and motor mount configuration do you have? It could be a matter of motor alignment. I have on occasion read about problems like this over at RCG with builders who had round booms and their motor mount(s) were not aligned perpendicular.
jbrumberg
Thanks for your response. Your frame probably rules out the possibility of a motor or motors being out of perpendicular. I have not flown in a very long time. I will think about this.
I hope that others will post. Have your tried RCG?
Good Luck-
JB
