Hi all ,, I am new to the KK 2.0 board and have been trying to just communicate with it for the last 2 weeks ... I have read every manual I can find and watched a ton of videos and still have no glory with her . I am using this flash tool : http://9xrprogrammer.com/index.php/shop/35-programming-6-pin and have the correct driver loaded . But it keeps giving me this error ::
avrdude.exe: error: programm enable: target doesn't answer. 1
avrdude.exe: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude.exe done. Thank you.
I have been in contact with the flash tool seller and he says there is usually no problem with the hardware .... could I maybe have a bad KK board that is making it not communicate ??? or maybe the wrong flash tool for the board ??? I notice that when the cable gets moved around that the usb connect to the computer tone will keep sounding off now and then ... like a loose connection ... I have tried all 3 of the usb ports on my computer ... and am at a standstill as what to do . Buy a new KK board and a new flash tool to try it all over ???? only to find out I have done something wrong in hook up >>> Help Thanks Larry
this check.
