KDE Direct's new XF-Series UAS Multi-Rotor ESC line
Garret H
We just got in our first shipment of KDE Direct's new XF-series UAS multi-rotor ESCs @ Altitude Hobbies and look awesome. Here's some of the key features:
  • Dynamic PWM and Motor Advance Timing algorithms provide industry-leading compatibility, specific tuning to the demands of the sUAS application, and simple plug-and-play installation with the world-class KDE Direct XF-Series Multi-Rotor Brushless Motor Series (sold separately).
  • Proprietary algorithm for up to 600Hz refresh rate control and high-speed response to flight system commands.
  • Highest-grade, extremely-low resistance (0.9 mΩ) MOSFETs for industry-leading performance and maximum efficiency.
  • 10,000+ hour, long-life and low-ESR Aluminum Electrolytic Capacitors are used for high-durability and maximum protection of the internal circuitry for optimal operation.
  • Critical internal components are protected by the thermal-epoxy bonded Aluminum 6061-T6 heatsink and a vibration-damping, foam composite backing.
<iframe width="640" height="360" src="//www.youtube.com/embed/d2y0TUwHc1Y" frameborder="0" allowfullscreen></iframe>
Click here for more info:
http://www.altitudehobbies.com/kde-uas-multi-rotor-escs
Garret
