GotHeliRC.com Hyperion Multione Vengeance Plug And Play FPV Racer NOW IN STOCK
GotHeliRC
http://gothelirc.com
IN STOCK READY TO SHIP.
Get 8x FREE HQPROP 5045 BULLNOSE
Introducing the Hyperion Multione Vengeance Plug And Play FPV Racer! Welcome to the new world of FPV Racing!
  • Fully Assembled: No building or firmware loading necessary!
  • On-Screen Display (OSD): Program or set up your Vengeance on-the-fly, no computer needed
  • In-Flight-Adjustable Single-Axis Camera Gimbal, Self-leveling during flight
  • Vibration Dampened Second-Camera Mount
  • 600TVl 1/3 CMOS High-Quality FPV Camera
  • Robust, Pure Carbon-Fiber Frame with Carbon Exoskeleton Reinforcements
  • Stress-Flex Designed to Withstand Impacts, Mass centralized for high-rate turning
  • Black-Anodized, High-Strength CNC Aluminum Boom Mounts
  • Tough, Translucent Polymer Landing Legs with Built-in Directional Red-Green LED
  • 8 Forward-Tilt Motor Mounts for Aerodynamic Efficiency and Top Speed Performance
  • Four 2804, 2300Kv High-Output Brushless Motors
  • Custom Compact BL-Heli 20A Motor Controllers (ESC)
  • Visual LED Flight Mode Indicator. Easy to confirm your flight mode
  • Pre-loaded with Three Flight Modes: Normal, Altitude Hold, or Acro Mode
  • NAZE Spec 32 Bit Flight Controller 7DOF (with BMP sensor)
  • Altitude Hold via Integrated Barometric Pressure Sensor (BMP)
  • 3S and 4S Battery Compatible. Hyperion G6 HV LiPo Suggested (not included)
  • 5.8GHz Auto-Scan 32CH Video Transmitter (VTX) w/ Race BandVTX selectable for either 20mw/200mw output
  • Tuned 5.8GHz CloverLeaf Skew-Planar Antenna
  • Plug-n-Play Ready for Optional GPS modules
  • Built-in Low-voltage Audible Alarm
  • Compatible with Single Wire* or Traditional Receivers (*S-Bus, Horizon Spektrum Satellite, or Hyperion Compatible receivers)
  • Box includes Carry Handle and Foam Racer Cradle + Parts Holder, for service as field case
  • One Set 5x3 CC/CCW Propellers Included
http://www.gothelirc.com/products/2...ngeance-280-plug-and-play-fpv-racer-in-stock/
Looks fun Vu, have you tried one yet? i like the design, the one-axis camera mount, compatible with Spektrum satellites, and the nice platform for a second recording camera.
should be a good product for people new to racing or that just want to get flying without the formalities of building something.
are the esc's separate or on one PCB?
GotHeliRC
I'm trying to bind one right now as we speak with the Hyperion Sat... I'm still too dumb for this.
Yes, esc is in the carbon arms. Power connect through main board using bullet, signal wire as well. Look like it can be replaced easily at the field if necessary. I believe this one is the winner right at this moment.
separate ESC's are nice too, those single PCB's with all of the motor control electronics on them are just a problem waiting to happen, IMHO
GotHeliRC
Maybe so... but oh boy, I enjoy it very much that's it's fully built ready to fly. Because I don't even have enough time to fly let alone build. :D
something about being in business for yourself does that to you!
