I have a Futaba 14SG and a 8FG and needed to buy a battery for the receiver.
The 8FG I bought 2nd hand and it was using a 2S Lipo
I called Ripmax to get the part number of the 8FG battery, and was told you can easily buy the battery, but the wall chargers can not be sold, as they have been removed for safety reasons as they do not pass some safety standard.
Now the 14SG battery is actually a 5 cell 6V NiMh battery 1800mA (10.8w) and on it, it says charging 170mA -15 hours
The 8FG battery is a 6 cell 7.2V NiMh battery 1800 mA with the same charging rate.
So a couple of questions.
When i first put the battery into the transmitter it said something like 5.4V
Obviously this is very low, and even below the recommended minimum of 1.1V/cell for NiMh, is this just because it is brand new, or should I be worried.
I plugged it into the Futaba wall charger for 2 hours, and now it says 8.4V which is a bit strange for only 2 hours.
The Futaba wall charger says sec: 4.8-6.0V - 600mAh, Im not even totally sure what that means, does it mean that it outputs 600mAh so should fully charge a battery within 3 hours?
Everything I have read says that I should be charging NiMh batteries at 0.1C which is about 180 mAh which should take 10 hours.
Can anyone enlighten me on the best way to charge the transmitter batteries, and what should the lowest/highest voltage be for these, I take it 1V for lowest and 1.4V-1.6V/cell for highest?
So in reality my tranmitter low voltage alarm should be set at 5.5V (1.1V/cell) for the 14SG and 6.6V for the 8FG?
If anyone can enlighten me of the dark new world of charging NiMh batteries I would be grateful.
