Hoverfly HoverFly Pro and expo!!
PaNt
Hello guys can you share your expos that you fly with your hfp??? Ithink that i need a lot of expo to smooth the machine..!!
DucktileMedia
I'm using the JR 9503 and I have a very healthy throttle curve between 30 and 80%. The expos are at 40%. Seems to be about as good as I need it. What's really amazing to me about what Hoverfly did with the sensitivity bar is that it flies really smoothly but still had enough authority at the end of my sticks to fly in 15+ mph wind.
Efliernz
Pete
I've got 40% on pitch and roll. 60% on yaw as it gives me a really slow yaw when required. i too have a healthy throttle curve :) I've flown my octo in 20+ mph and the it still rocks... you need to work at it but it will fly well.
Pete
Sorry for my ignorance. But what is a healthy throttle curve? Btw. my expos are to between 40 and 60%, but will have to go even higher for smooth video I think.
Marko
PaNt
OK guys thats whati use tooo! Because i was hearing smooth smooth smooth and in order to do something smooooooth i had to add 40-60expo..!
a throttle curve makes the throttle less responsive within certain ranges. it takes some tweaking but what you want to try to do is flatten out the throttle curve around the point where your helicopter hovers. that makes the motors less responsive to small changes in stick position resulting in a less sensitive helicopter. there are likely thousands of forum posts on throttle curves for helicopters so just do a google search and make sure you let us know if you find a good one! :)
to be honest, my throttle is still linear as the HFP is easy to fly. tweaking the throttle curve is something that is nice to do but won't make or break your flying experience.
bart
PaNt
bart
In order to smooth the copter you must tweak the throttle curve as the AIL and Elev for sure..!!
It depends on your setup too! I have 14x4.7 props..! Thats better for flying time but i think its a little more aggressive..! smaller props better flying characteristics..!
yes or no?/
I am flying 3d helis :)
Thats me with my Logo 400SE
http://www.youtube.com/watch?v=zzxqlo25Gd0
Thank you all. I'm aware of what the throttle curve does or is used for. Healthy was the word that I didn't understand. I suppose it's just curve that's flattened to a flyable (less responsive in our case) degree. And yes, everytime I adjust the curve it's more linear - I'm learning to fly obviously:)
Marko
yes or no?/
wow that was a crazy first flight! wouldn't it have been better to learn to fly heli's with something smaller and with less power? where's the x-shaped sticks on the landing gear with the ping-pong balls? it looks like you got a handle on it at the end, just in time to land. lucky for you, eh?
oh.....wait..........ummm.........that was supposed to..........ummmm......... be like that?
nevermind. :) nice vid.
bart
JZSlenker
Yeah, I can blow that up.
I use medium expo, a dual throttle curve, but what I use the most when flying is a momentary throttle hold switch. This lets you do pans without effecting throttle at all.
Aerovideo
I tend to fly pretty aggressively for my FPV videos so I have no expo or throttle curve but make very small stick movements. I guess I've just gotten used to that from helicopter days...
