I believe you need to upgrade your firmware. The problem you are describing happened on the first release and was corrected soon after. 1.03 is the latest I believe.
If this does not fix it then you are having a problem no one else is reporting. It must therefore be something in your setup such as where the board is mounted. Please refer to the manual.
Hi, Andre!
I do not use HoverflyGimbal. I use HoverflyPro to drive my gimbal.
Thanks!
Don't see anything in this thread about firmware version.
If you are posting the same problem in multiple threads it is difficult to keep up.
Lets make it clear.. He is using the HFPRO ONLY... He is using his Gimbal via HFP and not the HFgimbal..!
So its not the problem you say..!
