Hexa flies stable but camera control goes mad
broadwing
Hi Guys,
We have build a Hexa with WKM and 900 Mhz link activated well :).
If Hexa is switched on Camera mounts compensates smooth but....
When the Hexa flies stable but the camera mount (pitch) jitters and goes mad when flying.
HEXA XL
ESC. HiModel60A witchBEC output
Motor pulso 2826/ prop. XOAR 14x5
UAVFrame.com
Any suggestions??
I heard from friend that the BEC's could be cause of this problem??
Rgds.
Koos Maring
RTRyder
Merlin of Multirotors
Hi Guys,
HEXA XL
UAVFrame.com
Any suggestions??
Rgds.
Koos Maring
Are you using analog servos on the camera mount? If you are you may need to switch to digital servos. If you have digital servos, use a seperate BEC to power the servos and connect only the signal wire to the WKM.
broadwing
Hi Ken,
thanks for reply.
photoshipone with Hitec digital's.
I think it is the BEC voltage on the redwire's. I'll have to spend some time to disconnect as is build in very tight.
I'll keep you updated.
Further I've been flighing today with this Hexa and can you.... great. Almost no vibrations. It is heavy so hard to fly in the beginning.
But for MK people today I did some nice flight with a MK quad also.
Rgds,
Koos
